[postgis-devel] Question about EWKT and Dimension qualifiers
Sandro Santilli
strk at kbt.io
Sat Nov 9 02:51:53 PST 2019
On Fri, Nov 08, 2019 at 01:00:20PM +0100, Manuel Jesús Morillo wrote:
> Hi all!
> First of all I would like to say this is my first email in the list since I
> joined OSGeo some days ago so I am sorry if I miss something! :)
> I would like starting to contribute to Postgis and I was taking a look to
> the ticket #4561 <https://trac.osgeo.org/postgis/ticket/4561> when some
> questions came to my mind.
> At this moment the function ST_AsEwkt is missing the ZM for a 3-dimensional
> measured geometry:
> query: SELECT ST_AsEwkt(ST_GeomFromText('POINTZM(10 10 2 3)'));
> expected: POINT ZM (10 10 2 3)
> output: POINT(10 10 2 3)
EWKT stands for Extended Well Known Text, the specification does NOT
want ZM. You can read about EWKT in the doc/ZMSgeoms.txt file, under
section
2.3. Extensions to Well-Known-Text format
You can read it online at:
https://trac.osgeo.org/postgis/browser/git/doc/ZMSgeoms.txt#L173
It's a document from 2005, sent as a proposal to OGC for support
of higher-dimension geometries. The proposal was not accepted and
they ended up using the ZM prefix instead, which is why PostGIS
now supports both (and more) output types.
> So if we change "WKT_EXTENDED" to "WKT_EXTENDED | WKT_ISO" in LWGEOM_asEWKT
> / ST_AsEWKT then the SRID and ZM are kept:
I dubt WKT_EXTENDED and WKT_ISO are meant to be used as bitfields, use
either one or the other...
--strk;
