[postgis-devel] Postgis 3.1 minimum requirements update
Regina Obe
lr at pcorp.us
Mon Nov 11 07:27:44 PST 2019
I like the idea of making 9.6 the minimum because then all versions we support will support the PARALLEL code clause and one less version of PostgreSQL to keep testing.
+0 there
However I'm not seeing much else we gain by dropping from looking at the feature matrix. But there might be a lot of changes in underlying code paths to warrant it.
For reference I also like to look at the Feature Matrix -- https://www.postgresql.org/about/featurematrix/ to see what other old legacy code we can drop
There is CREATE EXTENSION CASCADE .. but that doesn't affect us too much since that doesn't support ALTER EXTENSION
GEOS upping to 3.8 - -0 on that. I just feel GEOS 3.8 is too new to make it a requirement. When we get closer to release time I may change my tune on that. I'd feel more comfortable once GEOS 3.9 is released. I do like that it will make some of our regression tests easier where GEOS 3.8 behaves differently from 3.7 and I think we have some code that tries to make GEOS 3.8 behave like old (or did we take it out).
So that said I'm not strongly opposed to making it the minimum.
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of rmrodriguez at carto.com
Sent: Monday, November 11, 2019 4:01 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: [postgis-devel] Postgis 3.1 minimum requirements update
Hi all,
I want to follow tradition an increase the minimum requirements for Postgis 3.1 dependencies:
Minimum PG version: 9.6 (was 9.5)
Recommended GEOS version: 3.8 (was 3.7)
There was some discussion about also upping the requirements for GDAL or PROJ in the past, so I think now is a good time to discuss it too in case any want wants to bring it to the table.
One minor doubt I have if whether to change the _PARALLEL macro to its proper value now, but I don't think it's really necessary (too many changes for no real value).
Regards,
Ra l Mar n Rodr guez
carto.com
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
