[postgis-devel] PostGIS 3.0.0 RC1 delayed
Sandro Santilli strk at kbt.io
Tue Oct 8 01:09:11 PDT 2019
On Mon, Oct 07, 2019 at 01:54:01PM +0200, Christoph Berg wrote:
> In 3.0-betaX, that worked. In rc1, regress/run_test.pl now guesses
> that the legacy test (only) is running from the build tree and doesn't
> use the files from /usr/share/postgresql/XX/contrib. The other tests
> still work.
Can you get to the exact run_test.pl invocation breaking ?
--strk;
