[postgis-devel] 3.0rc1 - libxml2-2 dependecy not found
Regina Obe lr at pcorp.us
Sat Oct 12 03:06:38 PDT 2019
No probably a packaging mistake on my part.
You can copy libxml2.dll to libxml2-2.dll  -- the one that ships with EDB should work fine.
Thanks for reporting,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Lauri Kajan
Sent: Saturday, October 12, 2019 3:26 AM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] 3.0rc1 - libxml2-2 dependecy not found
I tried to install PostGIS 3.0rc1 (winniebot zip) on a Postgresql 12 that was installed using the EDB Windows installer.
I got an error "could not load library C:\..\postgis-3.dll: The specified module could not be found." when doing the "create extension postgis".
I found out that postgis-3.dll depends on libxml2-2.dll which is not found. There is only a libxml2.dll in the bin folder.
Am I missing something or is this a bug and if so is it a known one?
Thanks,
-Lauri
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191012/5edf0db2/attachment.html>
