[postgis-devel] GIT repo: svn-trunk renamed to master
Sandro Santilli
strk at kbt.io
Mon Oct 28 00:54:07 PDT 2019
On Sun, Oct 27, 2019 at 08:54:22PM +0100, Sandro Santilli wrote:
> As part of the migration from SVN to GIT I created a "master" branch
> which deprecates the "svn-trunk" branch.
> This probably means any open pull request on any mirror ends up being
> based on a now-deleted branch and will need to be re-based. Sorry
> for that (I was convinced by Myon to do this, to share some of the
> blame :)
Update: the rename of svn-trunk to master resulted in GitHub closing
all pull requests targetting the now-deleted branch, without any
comment as to _why_ those PRs were closed. GitLab and Gitea pull
requests remained opened but pointing to a non-existing branch.
I've manually reopened and retargetted the the GitHub PRs
and retargetted the GitLab PRs.
Gitea does not support re-targetting via UI (yet, see
https://github.com/go-gitea/gitea/pull/6488) so those
ones I updated via SQL at the PostgreSQL level (juicy!)
--strk;
