[postgis-devel] Inconsistencies in text output
Martin Davis mtnclimb at gmail.com
Fri Apr 17 08:36:14 PDT 2020
On Fri, Apr 10, 2020 at 9:33 AM <rmrodriguez at carto.com> wrote:
> The first one does exactly what's documented in the functions
> themselves, that is if you request precision you get
> 1.111111100000000018 (before you got 1.1111111), but the diff is
> really massive (2435
> changes just in regress/).
Took a quick look at the first PR (with the large number of changes).
There seem to be a lot of changes which are changing the name of the test
function, but which are not changing the expected output).  Is that right?
If so, does that mean this change is not as large as mentioned above?
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200417/4faadc43/attachment.html>
