[postgis-devel] Function Removal
Regina Obe lr at pcorp.us
Wed Dec 16 12:12:59 PST 2020
: RE: [postgis-devel] Function Removal
> >   postgis=# select st_asewkt(ST_MakePoint(1.2, 2.33));
> >   ERROR:  function st_makepoint(double precision, double precision) is
> > not unique
> >   HINT:  Could not choose a best candidate function. You might need to
> > add explicit type casts.
> > Yeah, it could be either my new one or the two-parameter form of the
> > old one.
> > The obvious fix would be to remove the old signatures at the same time
> > as adding the new one, but as I recall this leads to upgrade issues?
> > This is where my memory is failing. I know (a) a single signature with
> > defaults and argument names is nicer and cleaner and also (b) every
> > time I've done it there's been some kind of an outcry / mess.
> > Any help, thoughts?
> > P
> This is for 3.2 (master) right, you aren't attempting this after we called
RC1
> right?
> The solution (though it may have changed with strk's voodoo) is, you add
the
> drop statement in
> postgis_before_upgrade.sql
One more note -- if you are replacing a C signature, you need to log the old
one  in postgis_legacy.c  otherwise pg_upgrade will complain.
