[postgis-devel] Function Removal
Regina Obe
lr at pcorp.us
Wed Dec 16 12:22:26 PST 2020
> > This is for 3.2 (master) right, you aren't attempting this after we
> > called
> > RC1 right?
> Yes, this is the joy of having an open master. Let your creativity run
free.
> > The solution (though it may have changed with strk's voodoo) is, you
> > add the drop statement in postgis_before_upgrade.sql
> OK, have done that. Will see what nasty things happen.
> P
Okay my debugging brain came up with the nasty thing of if someone has a
view that relies on the old signature then they can't upgrade because the
before drop will fail.
We never came up with the wonderful magic that would run a DROP AND CREATE
OR REPLACE view for them.
