[postgis-devel] Function Removal
Bruce Rindahl
bruce.rindahl at gmail.com
Wed Dec 16 15:55:02 PST 2020
Right now Select ST_AsText(ST_MakePoint(1,2,4326)) returns POINT Z (1 2
4326)
Are we going to have to cast the input every time to make sure it's a
SRID? That might be more confusing than ST_SetSRID(ST_MakePoint())
On Wed, Dec 16, 2020 at 11:41 AM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> I feel like we've been over this before, but I ran into it again and I'm
> wondering what we think our best practice should be.
> The issue is the removal of stacked multi-parameter functions. We have:
> CREATE FUNCTION ST_MakePoint(float8, float8)
> CREATE FUNCTION ST_MakePoint(float8, float8, float8)
> CREATE FUNCTION ST_MakePoint(float8, float8, float8, float8)
> What's missing here? A place to set the SRID! So we constantly have this
> formation:
> ST_SetSRID(ST_MakePoint(...), ...)
> Which is, let's face it, ugly. So being a smart boy I thought:
> CREATE FUNCTION ST_MakePoint(x float8, y float8, z float8 default null,
> m float8 default null, srid integer default null)
> And then I updated the underlying C function to handle the nulls, and it
> works wonderfully:
> postgis=# select st_asewkt(ST_MakePoint(1, 2, srid => 123));
> SRID=123;POINT(1 2)
> Except, unfortunately now the old form is broken.
> postgis=# select st_asewkt(ST_MakePoint(1.2, 2.33));
> ERROR: function st_makepoint(double precision, double precision) is not
> unique
> HINT: Could not choose a best candidate function. You might need to add
> explicit type casts.
> Yeah, it could be either my new one or the two-parameter form of the old
> one.
> The obvious fix would be to remove the old signatures at the same time as
> adding the new one, but as I recall this leads to upgrade issues? This is
> where my memory is failing. I know (a) a single signature with defaults and
> argument names is nicer and cleaner and also (b) every time I've done it
> there's been some kind of an outcry / mess.
> Any help, thoughts?
> P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201216/410c54ba/attachment.html>
