[postgis-devel] PostGIS 3.1.0alpha1 is released
Regina Obe
lr at pcorp.us
Sat Feb 1 16:24:35 PST 2020
The PostGIS Team is pleased to release the first alpha of upcoming PostGIS
3.1.0 release.
Related material:
Source Tar ball:
https://download.osgeo.org/postgis/source/postgis-3.1.0alpha1.tar.gz
HTML docs:
https://download.osgeo.org/postgis/docs/doc-html-3.1.0alpha1.tar.gz
PDF docs [EN]:
https://download.osgeo.org/postgis/docs/postgis-3.1.0alpha1.pdf
PDF docs [DE]:
https://download.osgeo.org/postgis/docs/postgis-3.1.0alpha1-de.pdf
This is the first release of PostGIS done after our move to Git and that
supports PostgreSQL 13 development release
Details of this release can be found in NEWS file:
https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.1.0alpha1/NEWS
Which is also included in source tar ball and in this email.
If you come across any issues, feel free to report via our ticket tracker
https://trac.osgeo.org/postgis or mailing list with details as described
here - https://postgis.net/support/
refer to
https://trac.osgeo.org/postgis/query?status=assigned&status=closed&milestone
=PostGIS+3.1.0 for details
NEWS worthy items
* Breaking changes *
- svn number replaced by git hash in version output
(Sandro Santilli, Raúl Marín)
- remove ChangeLog (anyone who needs that much info should refer to git
log)
(Regina Obe)
- #4577, Drop support for PostgreSQL 9.5 (Raúl Marín)
- #4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)
- #4601, ST_TileEnvelope signature changed.
- #3057, ST_Force3D, ST_Force3DZ, ST_Force3DM and ST_Force4D signatures
changed.
* New features *
- #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
- #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
- #4617, Add configure switch `--without-phony-revision` (Raúl Marín)
- #3057, Optional value params for Force3D*, Force4D functions (Kristian
Thy)
- #4624, ST_HexagonGrid and ST_SquareGrid, set returning functions to
generate tilings of the plane (Paul Ramsey)
* Enhancements *
- #4539, Unify libm includes (Raúl Marín)
- #4569, Allow unknown SRID geometry insertion into typmod SRID column
(Paul Ramsey)
- #4149, ST_Simplify(geom, 0) is now O(N).
ST_Affine (ST_Translate, ST_TransScale, ST_Rotate) optimized.
ST_SnapToGrid optimized. (Darafei Praliaskouski)
- #4574, Link Time Optimizations enabled (Darafei Praliaskouski)
- #4578, Add parallellism and cost properties to brin functions (Raúl
Marín)
- #4473, Silence yacc warnings (Raúl Marín)
- #4589, Disable C asserts when building without "--enable-debug" (Raúl
Marín)
- #4543, Introduce ryu to print doubles (Raúl Marín)
- #4626, Support pkg-config for libxml2 (Bas Couwenberg)
- #4615, Speed up geojson output (Raúl Marín)
* Bug fixes *
- #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
- #4545, Fix leak in wkt_parser_triangle_new (Raúl Marín)
- #4549, Fix several functions when the schema isn't the search_path (Raúl
Marín)
- #4546, Fix PLPGSQL functions missing the schema qualification (Raúl
Marín)
- #4558, Fix oversimplification of polygon inner rings (Raúl Marín)
- #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
- #4590, Fix pg_upgrade issue with st_linecrossingdirection (Raúl Marín)
- #4592, Add missing CPPFLAGS in multiple Makefiles (Raúl Marín)
- #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
- #4600, Improve precision of ST_TileEnvelope (Raúl Marín)
- #4608, PG12: Fix several bugs in the index support function (Raúl Marín)
- #4621, Prevent stack overflow when parsing WKB (Raúl Marín)
* Deprecated signatures *
- Function postgis_svn_version() replaced by postgis_lib_revision()
(Sandro Santilli)
Thanks,
PostGIS Development Team
