[postgis-devel] PSC Vote: Add Phillip Ross to PostGIS Docker Hub org
Yuri Astrakhan
yuriastrakhan at gmail.com
Tue Feb 4 11:54:35 PST 2020
Phillip, thanks, sounds reasonable.
I would guess we should simply transfer the repository ownership
from appropriate to postgis account, rather than fork and loose all the
issues/PRs/... work (there is a way to copy them too, but it won't be as
clean. Plus transfer leaves a redirect from the original URL)
On Tue, Feb 4, 2020 at 2:32 PM Phillip Ross <
phillip.w.g.ross+postgis at gmail.com> wrote:
> My perspective:
> I'd prefer a staged approach whereby we first host it within the
> postgis organization on github and dockerhub and then work on getting
> it into the docker-library. There are a few reasons for this.
> Firstly, the goal of taking over mdillon's maintainership without
> leaving consumers/contributors high and dry is a worthy goal. He's
> outlined a few issues
> (https://github.com/appropriate/docker-postgis/issues/143) around
> transitioning that need to be worked out, and currently there is
> activity (issues and PRs) that are getting stalled out due to being
> blocked on the transition. It would be a shame to lose contributors,
> so I see transitioning from mdillon's repos to postgis's repos as a
> lower barrier compared to all that's involved with getting into
> docker-library project.
> Secondly, I think the goal of getting latest and greatest postgresql
> and postgis images being produced is also a high priority. I've seen
> a lot of work being done in this vein, and I'd like to work on
> gathering and incorporating all the contributions that people have
> been making and try to centralize some evaluation and discussion of
> the approaches. This will work best after transitioning from
> mdillon's repos to repos in the postgis organization.
> Getting incorporated into docker-library would be really awesome, but
> I recall one of the suggestions getting incorporated into there is to
> build community activity. My instinct is that the two goals I stated
> above need to happen ASAP to avoid losing the community that already
> exists. While docker-library has an even larger community which is
> just another reason why it should be a goal to aim for, it's a bigger
> hurdle which will take more time.
> Thanks!
> - Phillip
> On Tue, Feb 4, 2020 at 1:52 PM Yuri Astrakhan <yuriastrakhan at gmail.com>
> wrote:
> > See the section "Creating new Repositories" and the sections after that
> -- I think we should actually push to move the existing postgis docker
> there, rather than host it as part of postgis repo -- a wider docker-aware
> community will be involved rather than purely postgis community.
> > https://github.com/docker-library/official-images
> > On Tue, Feb 4, 2020 at 1:47 PM Regina Obe <lr at pcorp.us> wrote:
> >> Didn’t even know there was such a thing. What’s involved to be
> sanctioned as an official image? If not too much work I’d say we should go
> for it.
> >> Thanks,
> >> Regina
> >> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
> Behalf Of Yuri Astrakhan
> >> Sent: Tuesday, February 4, 2020 1:32 PM
> >> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> >> Subject: Re: [postgis-devel] PSC Vote: Add Phillip Ross to PostGIS
> Docker Hub org
> >> P.S. This also raises a question -- can Postgis be published via the
> official channel as well -- this way it can be used without a prefix, i.e.
> "docker run postgis" instead of "docker run postgis/postgis"
> >> https://github.com/docker-library/postgres is the postgres repository.
> >> On Tue, Feb 4, 2020 at 1:29 PM Yuri Astrakhan <yuriastrakhan at gmail.com>
> wrote:
> >> On Tue, Feb 4, 2020 at 12:44 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> >> Is there an “official postgres image” we layer on, or is this something
> else? Does it layer on a particular linux image?
> >> It relies on two "official" (Docker-community maintained) docker
> images - postgres:<version> and postgres-alpine:<version> -- see
> https://hub.docker.com/_/postgres . The non-alpine uses
> debian:stretch-slim as the base image.
> >> The dockerfile example references:
> https://github.com/appropriate/docker-postgis/blob/master/11-2.5/Dockerfile#L1
> https://github.com/appropriate/docker-postgis/blob/master/11-2.5/alpine/Dockerfile#L1
> >> _______________________________________________
> >> postgis-devel mailing list
> >> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200204/2c1c6eef/attachment-0001.html>
