[postgis-devel] PSC Vote: Add Phillip Ross to PostGIS Docker Hub org
rmrodriguez at carto.com
Wed Feb 5 00:55:49 PST 2020
+1 to the proposal
A remainder: You probably don't want to use them, but we have some
scripts we use to build docker images for CI in
https://github.com/postgis/postgis-build-env
On Tue, Feb 4, 2020 at 9:56 PM Regina Obe <lr at pcorp.us> wrote:
> +1 to all you said :)
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Phillip Ross
> Sent: Tuesday, February 4, 2020 2:32 PM
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Subject: Re: [postgis-devel] PSC Vote: Add Phillip Ross to PostGIS Docker Hub org
> My perspective:
> I'd prefer a staged approach whereby we first host it within the postgis organization on github and dockerhub and then work on getting it into the docker-library. There are a few reasons for this.
> Firstly, the goal of taking over mdillon's maintainership without leaving consumers/contributors high and dry is a worthy goal. He's outlined a few issues
> (https://github.com/appropriate/docker-postgis/issues/143) around transitioning that need to be worked out, and currently there is activity (issues and PRs) that are getting stalled out due to being blocked on the transition. It would be a shame to lose contributors, so I see transitioning from mdillon's repos to postgis's repos as a lower barrier compared to all that's involved with getting into docker-library project.
> Secondly, I think the goal of getting latest and greatest postgresql and postgis images being produced is also a high priority. I've seen a lot of work being done in this vein, and I'd like to work on gathering and incorporating all the contributions that people have been making and try to centralize some evaluation and discussion of the approaches. This will work best after transitioning from mdillon's repos to repos in the postgis organization.
> Getting incorporated into docker-library would be really awesome, but I recall one of the suggestions getting incorporated into there is to build community activity. My instinct is that the two goals I stated above need to happen ASAP to avoid losing the community that already exists. While docker-library has an even larger community which is just another reason why it should be a goal to aim for, it's a bigger hurdle which will take more time.
> Thanks!
> - Phillip
> On Tue, Feb 4, 2020 at 1:52 PM Yuri Astrakhan <yuriastrakhan at gmail.com> wrote:
> > See the section "Creating new Repositories" and the sections after that -- I think we should actually push to move the existing postgis docker there, rather than host it as part of postgis repo -- a wider docker-aware community will be involved rather than purely postgis community.
> > https://github.com/docker-library/official-images
> > On Tue, Feb 4, 2020 at 1:47 PM Regina Obe <lr at pcorp.us> wrote:
> >> Didn t even know there was such a thing. What s involved to be sanctioned as an official image? If not too much work I d say we should go for it.
> >> Thanks,
> >> Regina
> >> Behalf Of Yuri Astrakhan
> >> Sent: Tuesday, February 4, 2020 1:32 PM
> >> Docker Hub org
> >> P.S. This also raises a question -- can Postgis be published via the official channel as well -- this way it can be used without a prefix, i.e. "docker run postgis" instead of "docker run postgis/postgis"
> >> https://github.com/docker-library/postgres is the postgres repository.
> >> On Tue, Feb 4, 2020 at 1:29 PM Yuri Astrakhan <yuriastrakhan at gmail.com> wrote:
> >> On Tue, Feb 4, 2020 at 12:44 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> >> Is there an official postgres image we layer on, or is this something else? Does it layer on a particular linux image?
> >> It relies on two "official" (Docker-community maintained) docker images - postgres:<version> and postgres-alpine:<version> -- see https://hub.docker.com/_/postgres . The non-alpine uses debian:stretch-slim as the base image.
> >> The dockerfile example references:
> >> https://github.com/appropriate/docker-postgis/blob/master/11-2.5/Dock
> >> erfile#L1
> >> https://github.com/appropriate/docker-postgis/blob/master/11-2.5/alpi
> >> ne/Dockerfile#L1
> >> _______________________________________________
> >> postgis-devel mailing list
> >> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Raúl Marín Rodríguez
carto.com
