[postgis-devel] About EXTENSION from UNPACKAGED on PostgreSQL 13
Sandro Santilli
strk at kbt.io
Thu Feb 27 00:58:21 PST 2020
On Thu, Feb 27, 2020 at 09:32:24AM +0100, Sandro Santilli wrote:
> On Wed, Feb 26, 2020 at 11:18:43AM -0500, Chapman Flack wrote:
> > On 2/26/20 10:52 AM, Sandro Santilli wrote:
> > > This part is not clear to me. You're _assuming_ that the unpackaged--xxx
> > > will not make checks, so you _drop_ support for it ? Can't the normal
> > > extension script also be unsafe for some reason ? Or can't the
> > > unpackaged-xxx script be made safe by the publishers ? Or, as a last
> > > resort.. can't you just mark postgis as UNSAFE and still require
> > > superuser, which would give us the same experience as before ?
> > I am wondering: does anything in the PG 13 change preclude writing
> > a postgis_raster--unpackaged.sql script that could be applied with
> > CREATE EXTENSION postgis_raster VERSION unpackaged;
> > and would do perhaps nothing at all, or merely confirm that the
> > right unpackaged things are present and are the right things...
> > ... from which an ALTER EXTENSION postgis_raster UPDATE TO 3.0;
> > would naturally run the existing postgis_raster--unpackaged--3.0.sql
> > and execute all of its existing ALTER EXTENSION ... ADD operations?
> > Has the disadvantage of being goofy, but possibly the advantage of
> > being implementable in the current state of affairs.
> Thanks for this hint, yes, seems to be technically feasible, as well
> as doing packaging in the extension creation scripts. Only... this
> would basically work around the intentionally removed syntax, which
> Steven Frost was against (still unclear to me why)...
NOTE: my suggestion was to directly have CREATE EXTENSION do the
packaging, which would give the same level of security as the
workaround suggested here, but with less hops.
--strk;
