[postgis-devel] 3.0.1 issues report
rmrodriguez at carto.com
Mon Jun 22 03:57:59 PDT 2020
On Mon, Jun 22, 2020 at 2:07 AM Greg Troxel <gdt at lexort.com> wrote:
> Some progress:
> If pkg-config is not available, then PROJ_LDFLAGS ends up empty
> instead of -lproj. However there is no error and proj is reproted
> found. I don't see in 2.5->3 NEWS that this is now required. I don't
> find that it is required in README.postgis.
This is a bug. We use to default to just trying to link to `lproj` if
the projdir wasn't declared, but now we are defaulting to that only if
the directory isn't passed and we have pkg-config but not proj
installed (or proj pre 4.8 is used, since that didn't have pkg-config
files). It is not handling correctly the option where projdir is not
passed and pkg-config isn't installed.
> Once I added pkg-config (as a declared dependency, making it
> available), I got a fatal error about json-c, that I also didn't find
> being a new requirement in NEWS. In README.postgis it says it is
> optional.
Another bug. We are using [] to tell PKG_CHECK_MODULES to do nothing
if json-c isn't found via pkg-config, but it interpretes that as "do
the default thing" which is throwing an error.
I've created a PR with both fixes
(https://github.com/postgis/postgis/pull/567) but it's really hard for
me to test this out. I've tested it by removing pkg-config and it
works, but removing json-c gets rid of almost half my OS and breaks
many other things. Could you give it a try, please?
> I wonder if the package should include protobuf-c; it seems useful to
> some and not that big so I will tend to include it.
I've considered removing the dependency and keeping it under dist/
with the pre-generated files and link it statically, but then it makes
updating or using dynamic linking for those to prefer it.
Raúl Marín Rodríguez
carto.com
