[postgis-devel] postgis_comments.sql
Tom van Tilburg tom.van.tilburg at gmail.com
Wed Mar 4 03:04:35 PST 2020
As a normal user who regularly builds his own postgis I have more than once
been interrupted by missing of even problematic docbook dependencies.
It would not be missed by me.
Tom
On Tue, Mar 3, 2020 at 12:01 AM Regina Obe <lr at pcorp.us> wrote:
> Added users to cc list to get more input.
> I have mixed feeling about this.  I see the value of not including it in
> extensions but would like to keep the make target.
> 1)      If you build from tar ball it’s already included built so you
> don’t need docbook to build extensions from tar ball.  But I guess if you
> build from git you do need dockbook. Given the craziness of our
> dependencies and the fact that most people don’t build their own PostGIS –
> the pain seems pretty minimal.
> 2)      Building the comments has on occasion prevented us from
> documenting things that aren’t so.  For example if you said in the docs the
> function signature is
> Foo(geometry, integer)
> And it was defined in the code as foo(geometry, integer[])
> Then the build would error out because the code doesn’t agree with the
> docs  – which I think is a nice feature.
> But that is the only really nice to have I can think of.  I suppose we
> could achieve the same by keeping the make target, but just don’t include
> it in extensions
> and have it as part of the ci steps to install the comments to confirm
> they install.
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Bruce Rindahl
> *Sent:* Monday, March 2, 2020 5:43 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* Re: [postgis-devel] postgis_comments.sql
> This:
> [image: image.png]
> then this:
> [image: image.png]
> vs this:
> https://postgis.net/docs/DropGeometryColumn.html
> I say it is a no brainer.  Especially since the function above is really
> not needed in PostGIS v3.0
> On Mon, Mar 2, 2020 at 2:34 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> I have long had an animus for the comments.sql file, because it results in
> a couple bad couplings:
> extension depends on comments depends on docbook, so you cannot build
> extension without having docbook/xslt tools installed
> extension depends on commetns depends on docbook, so you cannot change
> documentation format
> All this maybe would be worth choking down if the SQL comments provided
> any great value, but it’s not at all clear to me that they do. People
> lookup functions on postgis.net, on the google, but not in their SQL
> terminal monitors or object browsers.
> If we can find it without ourselves to not have SQL comments anymore, we
> can back out some of these weird dependencies.
> Taking the temperature, who would set themselves on fire to save SQL
> comments?
> P
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200304/405d3394/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200304/405d3394/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200304/405d3394/attachment-0003.png>
