[postgis-devel] When did ST_BuildArea change
Sandro Santilli
strk at kbt.io
Tue Oct 6 03:38:08 PDT 2020
On Mon, Oct 05, 2020 at 02:07:48PM -0700, Paul Ramsey wrote:
> 3.9, master, but with overlayng turned off... mind you, neither polygonize nor buildarea should call anything ng related? (I wonder of they do under the covers)
For the record: further discussion about this is in ticket
https://trac.osgeo.org/postgis/ticket/4763
where I think we finally figured when the behavior changed
(tltr: it worked by luck)
--strk;
