[postgis-devel] Windows Installer Issue
Gandalf the Gray
pjduplooy.gis at gmail.com
Sat Oct 17 01:26:16 PDT 2020
Hi guys
I am using the latest installer for PG 13, and everything installs
correctly. However when I do a select postgis_full_version(), I see the
following:
POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3"
SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 *GDAL_DATA
not found*" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3
(Internal)" TOPOLOGY RASTER
GDAL DATA however points to correct location in environment settings.
Nowhere in environment settings including path is there another GDAL DATA
setting.
select long_name from st_gdaldrivers() however shows results.
Can I ignore this?
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201017/922dc3b1/attachment.html>
