[postgis-devel] Windows Installer Issue
Regina Obe
lr at pcorp.us
Sat Oct 17 08:56:48 PDT 2020
Thanks for reporting. I’ll have to take a look at that. I was ignoring that one since I didn’t choose to override my env variable.
That setting is used for some raster processing and ogr_fdw. That could explain the errors I see with ogr_fdw character conversions.
If you aren’t using raster or ogr_fdw you can ignore it.
If you are using raster I don’t think it can be entirely ignored. I think it’s used for raster transformations. Ogr_fdw maybe. I’ll ticket as an issue and troubleshoot.
I’m guessing it has to do with the newer GDAL version and maybe our logic is looking for a file that is no longer present in the gdal-data folder as they did change the contents of gdal-data folder significantly between 2.4 and 3.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Gandalf the Gray
Sent: Saturday, October 17, 2020 4:26 AM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] Windows Installer Issue
Hi guys
I am using the latest installer for PG 13, and everything installs correctly. However when I do a select postgis_full_version(), I see the following:
POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3" SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 GDAL_DATA not found" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
GDAL DATA however points to correct location in environment settings. Nowhere in environment settings including path is there another GDAL DATA setting.
select long_name from st_gdaldrivers() however shows results.
Can I ignore this?
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201017/9be87de5/attachment.html>
