[postgis-devel] Windows Installer Issue
Bruce Rindahl
bruce.rindahl at gmail.com
Sat Oct 17 09:57:24 PDT 2020
Regina
While you are looking at this, do you have libiconv installed? I think
GDAL needs it but doesn't require it during configure.
On Sat, Oct 17, 2020, 8:56 AM Regina Obe <lr at pcorp.us> wrote:
> Thanks for reporting. I’ll have to take a look at that. I was ignoring
> that one since I didn’t choose to override my env variable.
> That setting is used for some raster processing and ogr_fdw. That could
> explain the errors I see with ogr_fdw character conversions.
> If you aren’t using raster or ogr_fdw you can ignore it.
> If you are using raster I don’t think it can be entirely ignored. I think
> it’s used for raster transformations. Ogr_fdw maybe. I’ll ticket as an
> issue and troubleshoot.
> I’m guessing it has to do with the newer GDAL version and maybe our logic
> is looking for a file that is no longer present in the gdal-data folder as
> they did change the contents of gdal-data folder significantly between 2.4
> and 3.
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Gandalf the Gray
> *Sent:* Saturday, October 17, 2020 4:26 AM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* [postgis-devel] Windows Installer Issue
> Hi guys
> I am using the latest installer for PG 13, and everything installs
> correctly. However when I do a select postgis_full_version(), I see the
> following:
> POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3"
> SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 *GDAL_DATA
> not found*" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
> WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
> GDAL DATA however points to correct location in environment settings.
> Nowhere in environment settings including path is there another GDAL DATA
> setting.
> select long_name from st_gdaldrivers() however shows results.
> Can I ignore this?
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201017/56722ce8/attachment.html>
