[postgis-devel] Windows Installer Issue
Bruce Rindahl bruce.rindahl at gmail.com
Mon Oct 19 10:03:35 PDT 2020
BTW, this is what triggered my questions about libiconv:
https://trac.osgeo.org/gdal/wiki/rfc23_ogr_unicode
FW gave a good roadmap on this subject.  Note he even suggested the
possibility of disabling the system iconv() in favor of libiconv
On Sat, Oct 17, 2020 at 10:33 AM Regina Obe <lr at pcorp.us> wrote:
> BTW I’ve ticketed this issue on:
> https://trac.osgeo.org/postgis/ticket/4766
> As far as libiconv goes hmm I’m not seeing a dependency of my GDAL 3.0.4
> compile on libiconv.  It’s also missing lib-curl which is going to annoy a
> lot of folks
> But I do see the dependency on my GDA: 2.4.4 –
> So that could be the problem we are seeing with ogr_fdw
> I’ll try to compile again and make sure the missing dependencies are there.
> Though I don’t think that is the culprit with the missing GDAL-DATA issue
> as I don’t think raster relies on libiconv
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Bruce Rindahl
> *Sent:* Saturday, October 17, 2020 12:57 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* Re: [postgis-devel] Windows Installer Issue
> Regina
> While you are looking at this, do you have libiconv installed?  I think
> GDAL needs it but doesn't require it during configure.
> On Sat, Oct 17, 2020, 8:56 AM Regina Obe <lr at pcorp.us> wrote:
> Thanks for reporting.  I’ll have to take a look at that.  I was ignoring
> that one since I didn’t choose to override my env variable.
> That setting is used for some raster processing and ogr_fdw.  That could
> explain the errors I see with ogr_fdw character conversions.
> If you aren’t using raster or ogr_fdw you can ignore it.
> If you are using raster I don’t think it can be entirely ignored.  I think
> it’s used for raster transformations.  Ogr_fdw maybe.  I’ll ticket as an
> issue and troubleshoot.
> I’m guessing it has to do with the newer GDAL version and maybe our logic
> is looking for a file that is no longer present in the gdal-data folder as
> they did change the contents of gdal-data folder significantly between 2.4
> and 3.
> Thanks,
> Regina
> Behalf Of *Gandalf the Gray
> *Sent:* Saturday, October 17, 2020 4:26 AM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* [postgis-devel] Windows Installer Issue
> Hi guys
> I am using the latest installer for PG 13, and everything installs
> correctly.  However when I do a select postgis_full_version(), I see the
> following:
> POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3"
> SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 *GDAL_DATA
> not found*" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
> WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
> GDAL DATA however points to correct location in environment settings.
> Nowhere in environment settings including path is there another GDAL DATA
> setting.
> select long_name from st_gdaldrivers() however shows results.
> Can I ignore this?
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201019/af3ab218/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201019/af3ab218/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201019/af3ab218/attachment-0003.png>
