[postgis-devel] Windows Installer Issue
Regina Obe lr at pcorp.us
Mon Oct 19 10:07:24 PDT 2020
Thanks.  I still have yet to look at this – I’ll try to get to it today and review this article.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bruce Rindahl
Sent: Monday, October 19, 2020 1:04 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Windows Installer Issue
BTW, this is what triggered my questions about libiconv:
https://trac.osgeo.org/gdal/wiki/rfc23_ogr_unicode
FW gave a good roadmap on this subject.  Note he even suggested the possibility of disabling the system iconv() in favor of libiconv
On Sat, Oct 17, 2020 at 10:33 AM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
BTW I’ve ticketed this issue on:
https://trac.osgeo.org/postgis/ticket/4766
As far as libiconv goes hmm I’m not seeing a dependency of my GDAL 3.0.4 compile on libiconv.  It’s also missing lib-curl which is going to annoy a lot of folks
But I do see the dependency on my GDA: 2.4.4 –
So that could be the problem we are seeing with ogr_fdw
I’ll try to compile again and make sure the missing dependencies are there.
Though I don’t think that is the culprit with the missing GDAL-DATA issue as I don’t think raster relies on libiconv
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of Bruce Rindahl
Sent: Saturday, October 17, 2020 12:57 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >
Regina
While you are looking at this, do you have libiconv installed?  I think GDAL needs it but doesn't require it during configure.
On Sat, Oct 17, 2020, 8:56 AM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Thanks for reporting.  I’ll have to take a look at that.  I was ignoring that one since I didn’t choose to override my env variable.
That setting is used for some raster processing and ogr_fdw.  That could explain the errors I see with ogr_fdw character conversions.
If you aren’t using raster or ogr_fdw you can ignore it.
If you are using raster I don’t think it can be entirely ignored.  I think it’s used for raster transformations.  Ogr_fdw maybe.  I’ll ticket as an issue and troubleshoot.
I’m guessing it has to do with the newer GDAL version and maybe our logic is looking for a file that is no longer present in the gdal-data folder as they did change the contents of gdal-data folder significantly between 2.4 and 3.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of Gandalf the Gray
Sent: Saturday, October 17, 2020 4:26 AM
To: postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Subject: [postgis-devel] Windows Installer Issue
Hi guys
I am using the latest installer for PG 13, and everything installs correctly.  However when I do a select postgis_full_version(), I see the following:
POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3" SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 GDAL_DATA not found" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
GDAL DATA however points to correct location in environment settings.  Nowhere in environment settings including path is there another GDAL DATA setting.
select long_name from st_gdaldrivers() however shows results.
Can I ignore this?
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201019/3826af68/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201019/3826af68/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201019/3826af68/attachment-0003.png>
