[postgis-devel] Pg13 upgrade issues?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 10 08:50:30 PDT 2020
I'm taking this from chat to email because chat isn't very durable.
As far as I can tell, we have outstanding Pg13 issues [1], demonstrable
just by running
make installcheck
At a minimum, the run_test.pl script in --extension --upgrade mode will
tests upgrades from 'unpackaged', which are now unavailable in Pg13. So
that test needs to be lopped out or version flagged.
More maximally, I am unsure what our situation is for 2.X->3.X upgrades,
since we were dependent on using the unpackaged source version to bundle up
the postgis_raster extension. Are we still? Is this something with a fix
planned, or is the fix to tell people "don't do that" and direct them
through an upgrade chain of 12/2->12/3->13/3?
I just confirmed that I can build, install and enable 2.5 under Pg13, so an
upgrade path via 12/3 could be a problem going forward.
POSTGIS="2.5.5dev r17978" [EXTENSION] PGSQL="130"
GEOS="3.9.0-CAPI-1.14.0"
Any information about current state of upgrade versus Pg13?
Thanks,
P
[1] https://trac.osgeo.org/postgis/ticket/4753
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200910/b28f0f6e/attachment.html>
