[postgis-devel] ST_GetValues()
Paul Ramsey
pramsey at cleverelephant.ca
Tue Apr 13 08:23:40 PDT 2021
More raster stuff, to go along with the surface interpolation and the contouring:
https://github.com/pramsey/postgis/tree/master-gdal-drape
An addition to ST_Value(), for the point-consuming variants, the implementation is now native not plpgsql, and there is a new optional argument at the end, "resample" which take either "nearest" or "bilinear".
CREATE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
RETURNS float8
AS 'MODULE_PATHNAME', 'RASTER_getPixelValueResample'
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
And building on that, ST_GetValues() which reads values from a raster into the Z or M coordinates of a reference geometry.
CREATE FUNCTION st_getvalues(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1, dimension text default 'z')
RETURNS geometry
AS 'MODULE_PATHNAME', 'RASTER_getGeometryValues'
Comments appreciated.
P
