[postgis-devel] ST_GetValues()
    Regina Obe
    lr at pcorp.us
    Thu Apr 15 22:02:50 PDT 2021
> And building on that, ST_GetValues() which reads values from a raster into
> the Z or M coordinates of a reference geometry.
> CREATE FUNCTION st_getvalues(rast raster, geom geometry, resample text
> DEFAULT 'nearest', band integer default 1, dimension text default 'z')
> 	RETURNS geometry
> 	AS 'MODULE_PATHNAME', 'RASTER_getGeometryValues'
> 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
> Comments appreciated.
> P
Why is this called ST_GetValues?  The Get seems a bit wordy and doesn't
follow the naming of other function.
Is there a reason you dismissed the more obvious to me ST_Values?
