[postgis-devel] ST_GetValues()
Paul Ramsey
pramsey at cleverelephant.ca
Fri Apr 16 10:21:42 PDT 2021
> On Apr 16, 2021, at 10:09 AM, Regina Obe <lr at pcorp.us> wrote:
>>> Speaking of which I forgot to ask if this is a set returning function.
>>> I assume not and you'd return a collection in cases where it's relevant?
>> It returns what you put in. Whatever geometry you put in, you get out,
> with
>> an extra Z or M dimension.
>> P
> Hmm so what happens if you pass in a polygon would it just interpolate the
> Z's in it.
> Wouldn't that often result in an invalid polygon? Like I would expect in
> many cases it would result in a polyhedralsurface or at very least a
> collection of polygonZs.
All that's happening under the covers is
foreach vertex in geometry
find raster value associated with vertex
add value to vertex Z or M
That's it.
P
> Points, Linestrings and multilinestrings yes that works great.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
