[postgis-devel] the_geom
Bruce Rindahl bruce.rindahl at gmail.com
Mon Aug 23 11:55:52 PDT 2021
A search for "the_geom" in the *.xml.po files gets 4327 hits in 182 files.
Do we want to change those?
On Sat, Aug 21, 2021 at 9:48 AM Martin Davis <mtnclimb at gmail.com> wrote:
> There are 50 XML doc files.  I believe the transifex files have extension
> .xml.po.
> On Sat, Aug 21, 2021 at 3:15 AM Sandro Santilli <strk at kbt.io> wrote:
>> On Fri, Aug 20, 2021 at 05:20:51PM -0400, Regina Obe wrote:
>> > I didn’t know we had that many doc files.  Even that is impressive :)
>> Note that many are generated via transifex (while still being put in
>> the git repository for autonomous updates)
>> --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210823/45892d3c/attachment.html>
