[postgis-devel] the_geom
Regina Obe
lr at pcorp.us
Mon Aug 23 13:37:34 PDT 2021
No need to change those. They will get fixed on the auto-push to transifex. Though speaking of which I’ve been lax in my monitoring of that so I need fix those. I think the building is broken at the moment
And I need to pull in the latest transifex changes.
I’ll do that after we push this big fat change and merge all the updated docs after.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bruce Rindahl
Sent: Monday, August 23, 2021 2:56 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] the_geom
A search for "the_geom" in the *.xml.po files gets 4327 hits in 182 files. Do we want to change those?
On Sat, Aug 21, 2021 at 9:48 AM Martin Davis <mtnclimb at gmail.com <mailto:mtnclimb at gmail.com> > wrote:
There are 50 XML doc files. I believe the transifex files have extension .xml.po.
On Sat, Aug 21, 2021 at 3:15 AM Sandro Santilli <strk at kbt.io <mailto:strk at kbt.io> > wrote:
On Fri, Aug 20, 2021 at 05:20:51PM -0400, Regina Obe wrote:
> I didn’t know we had that many doc files. Even that is impressive :)
Note that many are generated via transifex (while still being put in
the git repository for autonomous updates)
--strk;
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210823/b03f0408/attachment.html>
