[postgis-devel] Installation documentation
Regina Obe
lr at pcorp.us
Wed Aug 25 10:39:51 PDT 2021
Believe it or not that is a passed test – see the word “passed”
The intent was to make sure our interrupt logic can stop a process.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Brian M Hamlin
Sent: Wednesday, August 25, 2021 12:26 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>; Bruce Rindahl <bruce.rindahl at gmail.com>
Subject: Re: [postgis-devel] Installation documentation
in the GDAL build, some tests are meant to fail, and that is SUCCESS
no idea about the PostGIS ones --hth
On 8/25/21 9:19 AM, Bruce Rindahl wrote:
LOL - The documentation even has a failed test:
Test: test_lwgeom_segmentize2d ...NOTICE: ptarray.c:448 - ptarray_segmentize2d: Too many segments required (1.000000e+101)
NOTICE: liblwgeom code interrupted
passed
On Wed, Aug 25, 2021 at 8:48 AM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I don’t know what I was thinking when I put those in. Early on there were much fewer tests and then each release added more and more and raster and sfcgal addition made this exercise completely pointless but out of habit I kept on doing it.
I’d chuck them. Maybe keep the configure output.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of Bruce Rindahl
Sent: Wednesday, August 25, 2021 11:21 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >
Subject: [postgis-devel] Installation documentation
The file doc\installation.xml has about 700 lines of output from make check. Do we need all that? In addition, the verbiage is a few years old (PostgresQL-12dev) and depending on the build environment you will get different messages even with a clean build.
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210825/5efd37d5/attachment.html>
