[postgis-devel] Installation documentation
Bruce Rindahl
bruce.rindahl at gmail.com
Wed Aug 25 15:50:44 PDT 2021
Thanks. Brian explained it to me.
On Wed, Aug 25, 2021 at 10:39 AM Regina Obe <lr at pcorp.us> wrote:
> Believe it or not that is a passed test – see the word “passed”
> The intent was to make sure our interrupt logic can stop a process.
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Brian M Hamlin
> *Sent:* Wednesday, August 25, 2021 12:26 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>;
> Bruce Rindahl <bruce.rindahl at gmail.com>
> *Subject:* Re: [postgis-devel] Installation documentation
> in the GDAL build, some tests are meant to fail, and that is SUCCESS
> no idea about the PostGIS ones --hth
> On 8/25/21 9:19 AM, Bruce Rindahl wrote:
> LOL - The documentation even has a failed test:
> Test: test_lwgeom_segmentize2d ...NOTICE: ptarray.c:448 -
> ptarray_segmentize2d: Too many segments required (1.000000e+101)
> NOTICE: liblwgeom code interrupted
> passed
> On Wed, Aug 25, 2021 at 8:48 AM Regina Obe <lr at pcorp.us> wrote:
> I don’t know what I was thinking when I put those in. Early on there were
> much fewer tests and then each release added more and more and raster and
> sfcgal addition made this exercise completely pointless but out of habit I
> kept on doing it.
> I’d chuck them. Maybe keep the configure output.
> Behalf Of *Bruce Rindahl
> *Sent:* Wednesday, August 25, 2021 11:21 AM
> *Subject:* [postgis-devel] Installation documentation
> The file doc\installation.xml has about 700 lines of output from make
> check. Do we need all that? In addition, the verbiage is a few years old
> (PostgresQL-12dev) and depending on the build environment you will get
> different messages even with a clean build.
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210825/62192cc5/attachment.html>
