[postgis-devel] [postgis-users] PSC Vote: Keep or drop Flatgeobuf in PostGIS 3.2.0
Bruce Rindahl
bruce.rindahl at gmail.com
Thu Dec 16 11:46:05 PST 2021
Not sure how I control that. If I set a max zoom in leaflet, the layer
disappears below that level. I am using GeoServer to create/send the tiles
and there is no option on zoom levels.
On Thu, Dec 16, 2021 at 11:13 AM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> You're not supposed to ever need more than 14 levels of MVT.
> On Thu, Dec 16, 2021 at 9:14 PM Bruce Rindahl <bruce.rindahl at gmail.com>
> wrote:
>> Let me see if I can get a handle on the size. I just started a full seed
>> on level 19. It will take 4 days to run.
>> On Thu, Dec 16, 2021 at 10:07 AM Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> > On Dec 16, 2021, at 10:04 AM, Bruce Rindahl <bruce.rindahl at gmail.com>
>>> wrote:
>>> > MVT takes up a LOT of disk space. The advantage is thousands of small
>>> files that Leaflet only asks for the tiles in the view and can cache the
>>> tiles.
>>> Does it? I would think the quantization would generally make them
>>> smaller (though the dictionary handling of attributions and redudant
>>> repetition from tile-to-tile of attributes could easily wash that out for
>>> an attributively rich data set.
>>> P
>>> > I haven't done a full seed of the smallest level as that would take
>>> days and days. They are generated on the fly as requested and served
>>> directly after that.
>>> > On Wed, Dec 15, 2021 at 7:01 PM Regina Obe <lr at pcorp.us> wrote:
>>> > Just curious what are your MVT sizes comparable for you deepest tile
>>> level.
>>> > I was hoping it would be better than Shapefile but guess not always,
>>> but good to see it is better than GeoJSON.
>>> > Thanks,
>>> > Regina
>>> > From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
>>> Behalf Of Bruce Rindahl
>>> > Sent: Wednesday, December 15, 2021 7:29 PM
>>> > To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
>>> > Subject: Re: [postgis-devel] [postgis-users] PSC Vote: Keep or drop
>>> > Doing a quick test with the wildfires in CA the past 3 years.
>>> > Shapefile = 9.42 MB
>>> > GeoJSON = 26.5 MB
>>> > FlatGeobuf = 9.42 MB
>>> > Right now I am serving the fires up via MVT on open layers and will
>>> try to add a FlatGeobuf layer for testing.
>>> > Generated the file via ogr2ogr and will test when postGIS 3.2 is out
>>> but it does look like a compact format. QGIS imports it with no issues.
>>> As an exchange format it will have to be on the command line via ogr2ogr or
>>> psql either via GDAL or native postGIS
>>> > On Thu, Nov 25, 2021 at 9:08 AM Jeff McKenna <
>>> jmckenna at gatewaygeomatics.com> wrote:
>>> > As an aside, I appreciate this explanation on speed and benefits,
>>> Björn,
>>> > of FlatGeobuf. Thanks,
>>> > -jeff
>>> > Jeff McKenna
>>> > GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>>> > co-founder of FOSS4G
>>> > http://gatewaygeo.com/
>>> > _______________________________________________
>>> > postgis-devel mailing list
>>> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20211216/8217b9a0/attachment.html>
