[postgis-devel] [postgis-users] PSC Vote: Keep or drop Flatgeobuf in PostGIS 3.2.0
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Thu Dec 16 11:13:09 PST 2021
You're not supposed to ever need more than 14 levels of MVT.
On Thu, Dec 16, 2021 at 9:14 PM Bruce Rindahl <bruce.rindahl at gmail.com>
wrote:
> Let me see if I can get a handle on the size. I just started a full seed
> on level 19. It will take 4 days to run.
> On Thu, Dec 16, 2021 at 10:07 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> > On Dec 16, 2021, at 10:04 AM, Bruce Rindahl <bruce.rindahl at gmail.com>
>> wrote:
>> > MVT takes up a LOT of disk space. The advantage is thousands of small
>> files that Leaflet only asks for the tiles in the view and can cache the
>> tiles.
>> Does it? I would think the quantization would generally make them smaller
>> (though the dictionary handling of attributions and redudant repetition
>> from tile-to-tile of attributes could easily wash that out for an
>> attributively rich data set.
>> P
>> > I haven't done a full seed of the smallest level as that would take
>> days and days. They are generated on the fly as requested and served
>> directly after that.
>> > On Wed, Dec 15, 2021 at 7:01 PM Regina Obe <lr at pcorp.us> wrote:
>> > Just curious what are your MVT sizes comparable for you deepest tile
>> level.
>> > I was hoping it would be better than Shapefile but guess not always,
>> but good to see it is better than GeoJSON.
>> > Thanks,
>> > Regina
>> > From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
>> Behalf Of Bruce Rindahl
>> > Sent: Wednesday, December 15, 2021 7:29 PM
>> > To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
>> > Subject: Re: [postgis-devel] [postgis-users] PSC Vote: Keep or drop
>> > Doing a quick test with the wildfires in CA the past 3 years.
>> > Shapefile = 9.42 MB
>> > GeoJSON = 26.5 MB
>> > FlatGeobuf = 9.42 MB
>> > Right now I am serving the fires up via MVT on open layers and will try
>> to add a FlatGeobuf layer for testing.
>> > Generated the file via ogr2ogr and will test when postGIS 3.2 is out
>> but it does look like a compact format. QGIS imports it with no issues.
>> As an exchange format it will have to be on the command line via ogr2ogr or
>> psql either via GDAL or native postGIS
>> > On Thu, Nov 25, 2021 at 9:08 AM Jeff McKenna <
>> jmckenna at gatewaygeomatics.com> wrote:
>> > As an aside, I appreciate this explanation on speed and benefits,
>> Björn,
>> > of FlatGeobuf. Thanks,
>> > -jeff
>> > Jeff McKenna
>> > GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>> > co-founder of FOSS4G
>> > http://gatewaygeo.com/
>> > _______________________________________________
>> > postgis-devel mailing list
>> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20211216/9fe8e112/attachment-0001.html>
