[postgis-devel] Google Summer of Code 2021
Regina Obe
lr at pcorp.us
Mon Feb 8 11:15:41 PST 2021
Giuseppe,
If you are willing to do the mentoring I see no issue with it and would be a nice feature to have.
We have had a couple of GSOC students in prior years, but none this year to my knowledge. Last one we had implemented the pgAdmin4 geometry viewer plugin, which was a huge benefit to many.
As far as GSOC for PostGIS goes – we usually do it under the OSGeo umbrella. I can follow-up with OSGeo GSOC community to get PostGIS in the mix, if all are okay with this proposal.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Giuseppe Broccolo
Sent: Monday, February 8, 2021 1:58 PM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] Google Summer of Code 2021
Recently this patch <https://commitfest.postgresql.org/29/2276/> which adds more infrastructure to the GiST has been included in PG14. It should speed up the build of a GiST index after some (fast) pre-sorting of the data which needs to be indexed. Some tests for the PG's internal type point (that uses Zsort as fast pre-sorting of the data) showed that the build is up to 5 times faster.
I'd like to study a possible implementation for PostGIS data types. Basically, it would require to add this support function <https://github.com/glukhovn/postgres/blob/225a49161fae9388651373d4beb8dcba99059339/src/include/access/gist.h#L37> and this other one <https://github.com/glukhovn/postgres/blob/225a49161fae9388651373d4beb8dcba99059339/src/include/access/gist.h#L38> in the operator classes which use the GiST infrastructure (e.g. this one <https://github.com/postgis/postgis/blob/8b13c3e2f8366d902dbf516ec17de09ae84361f4/postgis/postgis.sql.in#L781> ).
I was wondering if we could take the opportunity to have some support even by the students of the Google Summer of Code of this year. I'd be happy to do some mentorship in order to get this done in the 180 hours required by the committee.
First of all I'd like to ask your opinion: do you think it would be a good idea to involve a student? Is there any other application for PostGIS project at the GSOC?
Link to the GSOC <https://opensource.googleblog.com/2020/10/google-summer-of-code-2021-is-bringing.html> (info about the timeline here <https://developers.google.com/open-source/gsoc/timeline> ).
Thanks,
Giuseppe.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210208/fd7f328d/attachment.html>
