[postgis-devel] ST_Union for TopoGeometry (misnamer?)
Sandro Santilli strk at kbt.io
Wed Feb 17 11:13:08 PST 2021
Hi all,
I've been working on a function for adding the components
of a topologically defined geometry (src TopoGeometry) to the
components of another one (tgt TopoGeometry).
In my current draft [1] this function has signature:
  toTopoGeom(src TopoGeometry, tgt TopoGeometry)
But when approaching documenting it, I figured that "toTopoGeom"
is documented to _convert_ simple geometries to TopoGeometris
while in this function there's no conversion at all.
So, the question is: would you find ST_Union [2] an appropriate
name for the function, even if it would raise an exception
when trying to union "incompatible" TopoGeometries (defined on
different topologies or different hierarchies?)
That is: is it acceptable for ST_Union(tg1, tg2) to fail
when ST_Union(tg1::geometry, tg2::geometry) would succeed ?
Your brain power is welcome :)
[1] https://gitlab.com/postgis/postgis/-/merge_requests/20
[2] https://trac.osgeo.org/postgis/ticket/4847
--strk;
