[postgis-devel] 3.1.1 Release
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Wed Jan 27 12:59:32 PST 2021
+1
On Wed, Jan 27, 2021 at 11:45 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Given that we're carrying a crasher in 3.1.0, I'd like to propose release
> of 3.1.1 right away.
> +1
> ---------- Forwarded message ---------
> From: Paul Ramsey <pramsey at cleverelephant.ca>
> Date: Wed, Jan 27, 2021 at 12:23 PM
> Subject: Re: [postgis-users] Postgis 3.1.0 st_makevalid crashes the
> PostgreSQL Server
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> My installation of master on both PostGIS and GEOS does not crash, but
> rolling back to PostGIS 3.1.0 and GEOS master crashes. I think we should
> push out a minor PostGIS release ASAP.
> On Tue, Jan 26, 2021 at 3:37 AM Nicolas Ribot <nicolas.ribot at gmail.com>
> wrote:
>> With geos-master (3.10.0dev-CAPI-1.15.0), the buffer query from json
>> polygon works and returns a valid polygon, but makevalid on empty geoms
>> still crashes PG
>> Nicolas
>> On Tue, 26 Jan 2021 at 12:01, Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>>> Hi,
>>> I could also reproduce it on MacOS
>>> (POSTGIS="3.1.0 5e2af69" [EXTENSION] PGSQL="130"
>>> GEOS="3.9.0-CAPI-1.16.2" SFCGAL="1.3.9" PROJ="7.2.0" GDAL="GDAL 3.2.0,
>>> released 2020/10/26" LIBXML="2.9.4" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
>>> WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER)
>>> The buffer operation returns an empty polygon.
>>> Running these queries crashes the backend (server process (PID 93524)
>>> was terminated by signal 6: Abort trap: 6):
>>> select st_makeValid(st_multi('POLYGON EMPTY'::geometry));
>>> select st_makeValid('GEOMETRYCOLLECTION EMPTY'::geometry);
>>> select st_makeValid('MULTIPOLYGON EMPTY'::geometry);
>>> Nicolas
>>> On Mon, 25 Jan 2021 at 11:52, Fatih Sazan <fatihsazan01 at gmail.com>
>>> wrote:
>>>> my postgis verison details:
>>>> SELECT postgis_full_version();
>>>> GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.7" LIBJSON="0.13.1"
>>>> LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" (core procs from "3.1.0alpha2
>>>> b6f415d" need upgrade) TOPOLOGY (topology procs from "3.1.0alpha2 b6f415d"
>>>> need upgrade)
>>>> Bjornar Skinnes <bjornar_skinnes at trimble.com>, 25 Oca 2021 Pzt, 11:40
>>>> tarihinde şunu yazdı:
>>>>> postgis/postgis:latest image today. So I also could reproduce this
>>>>> error. fyi.
>>>>> GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 5.2.0, September 15th, 2018"
>>>>> LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1" WAGYU="0.5.0
>>>>> man. 25. jan. 2021 kl. 09:35 skrev Sandro Santilli <strk at kbt.io>:
>>>>>> On Mon, Jan 25, 2021 at 10:19:42AM +0300, Fatih Sazan wrote:
>>>>>> > When I run my code running on PostGIS version 2.5, I don't get an
>>>>>> error but
>>>>>> > when I run it on 3.1 it the server gives an error and enters the
>>>>>> recovery
>>>>>> > mode every time.
>>>>>> > Operating System: CentOS Linux 8
>>>>>> > CPE OS Name: cpe:/o:centos:centos:8
>>>>>> > Kernel: Linux 4.18.0-193.28.1.el8_2.x86_64
>>>>>> > Architecture: x86-64
>>>>>> > postgresql-13
>>>>>> > extension : postgis vers. 3.1.0
>>>>>> This should be fixed by upgrading GEOS.
>>>>>> What version of GEOS are you using ?
>>>>>> It should be reported by:
>>>>>> --strk;
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
OSM BY Team - http://openstreetmap.by/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210127/bbe9562f/attachment.html>
