[postgis-devel] 3.1.1 Release
Paragon Corporation
lr at pcorp.us
Wed Jan 27 13:04:08 PST 2021
+1
On Wed, Jan 27, 2021 at 3:59 PM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> +1
> On Wed, Jan 27, 2021 at 11:45 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Given that we're carrying a crasher in 3.1.0, I'd like to propose release
>> of 3.1.1 right away.
>> +1
>> ---------- Forwarded message ---------
>> From: Paul Ramsey <pramsey at cleverelephant.ca>
>> Date: Wed, Jan 27, 2021 at 12:23 PM
>> Subject: Re: [postgis-users] Postgis 3.1.0 st_makevalid crashes the
>> PostgreSQL Server
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> My installation of master on both PostGIS and GEOS does not crash, but
>> rolling back to PostGIS 3.1.0 and GEOS master crashes. I think we should
>> push out a minor PostGIS release ASAP.
>> On Tue, Jan 26, 2021 at 3:37 AM Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>>> With geos-master (3.10.0dev-CAPI-1.15.0), the buffer query from json
>>> polygon works and returns a valid polygon, but makevalid on empty geoms
>>> still crashes PG
>>> Nicolas
>>> On Tue, 26 Jan 2021 at 12:01, Nicolas Ribot <nicolas.ribot at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I could also reproduce it on MacOS
>>>> (POSTGIS="3.1.0 5e2af69" [EXTENSION] PGSQL="130"
>>>> GEOS="3.9.0-CAPI-1.16.2" SFCGAL="1.3.9" PROJ="7.2.0" GDAL="GDAL 3.2.0,
>>>> released 2020/10/26" LIBXML="2.9.4" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
>>>> WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER)
>>>> The buffer operation returns an empty polygon.
>>>> Running these queries crashes the backend (server process (PID 93524)
>>>> was terminated by signal 6: Abort trap: 6):
>>>> select st_makeValid(st_multi('POLYGON EMPTY'::geometry));
>>>> select st_makeValid('GEOMETRYCOLLECTION EMPTY'::geometry);
>>>> select st_makeValid('MULTIPOLYGON EMPTY'::geometry);
>>>> Nicolas
>>>> On Mon, 25 Jan 2021 at 11:52, Fatih Sazan <fatihsazan01 at gmail.com>
>>>> wrote:
>>>>> my postgis verison details:
>>>>> SELECT postgis_full_version();
>>>>> GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.7" LIBJSON="0.13.1"
>>>>> LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" (core procs from "3.1.0alpha2
>>>>> b6f415d" need upgrade) TOPOLOGY (topology procs from "3.1.0alpha2 b6f415d"
>>>>> need upgrade)
>>>>> Bjornar Skinnes <bjornar_skinnes at trimble.com>, 25 Oca 2021 Pzt, 11:40
>>>>> tarihinde şunu yazdı:
>>>>>> postgis/postgis:latest image today. So I also could reproduce this
>>>>>> error. fyi.
>>>>>> GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 5.2.0, September 15th, 2018"
>>>>>> LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1" WAGYU="0.5.0
>>>>>> man. 25. jan. 2021 kl. 09:35 skrev Sandro Santilli <strk at kbt.io>:
>>>>>>> On Mon, Jan 25, 2021 at 10:19:42AM +0300, Fatih Sazan wrote:
>>>>>>> > When I run my code running on PostGIS version 2.5, I don't get an
>>>>>>> error but
>>>>>>> > when I run it on 3.1 it the server gives an error and enters the
>>>>>>> recovery
>>>>>>> > mode every time.
>>>>>>> > Operating System: CentOS Linux 8
>>>>>>> > CPE OS Name: cpe:/o:centos:centos:8
>>>>>>> > Kernel: Linux 4.18.0-193.28.1.el8_2.x86_64
>>>>>>> > Architecture: x86-64
>>>>>>> > postgresql-13
>>>>>>> > extension : postgis vers. 3.1.0
>>>>>>> This should be fixed by upgrading GEOS.
>>>>>>> What version of GEOS are you using ?
>>>>>>> It should be reported by:
>>>>>>> --strk;
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list
>>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> OSM BY Team - http://openstreetmap.by/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210127/30d7630e/attachment-0001.html>
