[postgis-devel] [SoC] GSoC 2021 - Week 3 Report - Implement pre-sorting methods before GiST index building
Regina Obe lr at pcorp.us
Thu Jul 1 07:18:20 PDT 2021
Han,
Yah regress/real is just to start the setup.
I was hoping you’d do a pull request with some more tests to that.  Basically whatever you’ve been testing but using the data provided via the download.
I have the basics of a testing bot going.
https://debbie.postgis.net/job/PostGIS_Test_Worker_Run/49/label=reallie/consoleFull
I think I mentioned that to you, but still need to make so tweaks.  When I’m done I’ll give you a link you can trigger tests from her.
I can also point her at your repo so she can test against your repo.
Thanks,
Regina
Sent: Thursday, July 1, 2021 9:54 AM
To: Regina Obe <lr at pcorp.us>; Giuseppe Broccolo <g.broccolo.7 at gmail.com>
Cc: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] [SoC] GSoC 2021 - Week 3 Report - Implement pre-sorting methods before GiST index building
Hi Regina and hi Giuseppe,
I have tested with some real data in `osm_china` with .sql scripts. And it works normally with several outputs. But I think the details of /regress/read need to be modified for further uses.
Moreover, I would like to know how to prepare for the first period evaluation?
Best regards,
Han
On Tue, Jun 29, 2021 at 10:24 AM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
>  - I hope you're using at least a couple millions of objects. If not, take any OpenStreetMap country (I use Belarus usually), get it to the db (osmium-tool and its osmium export -f pg is good) and index that.
[Regina Obe]
Darafei and Han,
I packaged Belarus osm data up from https://download.geofabrik.de/europe/belarus-latest.osm.pbf
And have as an sql loadable script
https://postgis.net/extra/test-data/osm_belarus.sql.bz2
I’ve added it to the regress/real/download_data.sh script
I used ogr2ogr to load into PostgreSQL.  Not sure how it compares to osmium structure or if it matters much.
Thanks,
Regina
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210701/703d796b/attachment-0001.html>
