[postgis-devel] protobuf-c configure test dropping LDFLAGS needed for conftest to run
Dr. Thomas Orgis thomas.orgis at uni-hamburg.de
Sat Jul 24 06:52:08 PDT 2021
I'm just dopping by to suggest a change to the configure script to make
it work in environments where LDFLAGS in the envrionment are actually
necessary, like some RPATH-related settings in there.
The strangely elaborate checking of protobuf-c (instead of just being
content with what pkg-config tells us, like --modversion) wants to run
the linked conftest binary, which fails to do so because of this:
(https://git.osgeo.org/gitea/postgis/postgis/src/branch/main/configure.ac line 1035)
        if test -n "$PROTOBUF_LDFLAGS"; then
		LDFLAGS="$PROTOBUF_LDFLAGS"
	fi
I suggest that to be changed to
		LDFLAGS="$LDFLAGS $PROTOBUF_LDFLAGS"
	fi
to keep honouring things like -Wl,R/prefix/of/protobuf/lib. With this
change, I can build postgis on my setup where such is the case.
Alrighty then,
Thomas
Dr. Thomas Orgis
HPC @ Universität Hamburg
