[postgis-devel] docker hub image is behind
Imre Samu
pella.samu at gmail.com
Sat Jun 5 13:57:23 PDT 2021
status:
The master update problem has been resolved. Thank you for solving the
issue!
The latest postgis master available:
- postgis/postgis:12-master
- postgis/postgis:13-master
https://registry.hub.docker.com/r/postgis/postgis/tags?page=1&ordering=last_updated&name=master
https://github.com/postgis/docker-postgis/pull/238
ENV SFCGAL_GIT_HASH 0beb9d6dde86467d412e70037dca0e00091e673e
ENV PROJ_GIT_HASH dcc2a94eb1c5eda5ede6275b58ae5873e78bb9c0
ENV GEOS_GIT_HASH 02f912883af916e2eb99a090255c9302a155e092
ENV GDAL_GIT_HASH e635362bb1a3c517489cc4d09fe2a41f0869c199
ENV POSTGIS_GIT_HASH 429bf56aa47e55a13555a15d20ef08a1c14d2aba
The "update" part ( calling ./update.sh ) is still manual.
We are waiting for the official PG14 docker images.
so there is no "postgis/postgis:14-master" yet.
Imre
Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2021. máj. 19., Sze,
18:15):
> my guess: probably it is a Geos 3.10 related problem.
> And as I see: the similar - "latest" CI check has been removed on Apr 28,
> 2021 by Paul Ramsey
> https://github.com/postgis/postgis/commit/982d725906c4ae69dab3d11e69432f8a7e51b90e
> the latest "~good???" Postgis version with the new geos:
> 2851cd1908dc138d6a6ec389fdbedc8fc93f5e73 ( ~ Apr 27, 2021 )
> IMHO: options:
> a.) wait for the "root cause" fix
> b.) set Postgis to ~Apr 27, 2021 ->
> https://github.com/postgis/docker-postgis/pull/236/files
> ( from d5f7a2adc923869ebe17b5fd0a6fa299d5b9c20c ~ Commits on Mar 30,
> 2021 )
> c.) other alternatives
> Imre
> Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2021. máj. 18., K,
> 18:43):
>> Thank you, Giuseppe and Phillip - for the tips!
>> I have tried - to build on my local machine, and has a similar result :-(
>> docker build -t postgis:13-master ./13-master
>> Run tests: 150
>> Failed: 23
>> make: *** [runtest.mk:11: check-regress] Error 23
>> I have refreshed to the latest proj,gdal .. And waiting for the new
>> github test.
>> https://github.com/postgis/docker-postgis/pull/235
>> For Geos 3.10 - just only this issue reported:
>> "ClipByBox2D against GEOS 3.10 head failing"
>> https://trac.osgeo.org/postgis/ticket/4904
>> > Before putting much work into bisecting commit logs and trying to find
>> > the most recent working commit,
>> probably, I just lock the ~ one-month-old PROJ + GEOS master version
>> Or just manually updating the PostGIS hash
>> ( without finding the real root cause )
>> Imre
>> Phillip Ross <phillip.w.g.ross+postgis at gmail.com> ezt írta (időpont:
>> 2021. máj. 18., K, 17:49):
>>> Hi Imre,
>>> I took a look at the logs and the failures look a little peculiar. It
>>> might be a github actions issue, as Giuseppe mentioned.
>>> the most recent working commit, you might want to try to just re-run
>>> the jobs in the actions tab and see if the failures were an
>>> intermittent issue.
>>> Thanks!
>>> - Phillip
>>> On Tue, May 18, 2021 at 11:17 AM Imre Samu <pella.samu at gmail.com> wrote:
>>> > Ouch; Failed.
>>> > 12-master:
>>> > Run tests: 150
>>> > Failed: 17
>>> > make: *** [runtest.mk:11: check-regress] Error 17
>>> > full log:
>>> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659927
>>> > 13-master:
>>> > Run tests: 150
>>> > Failed: 13
>>> > make: *** [runtest.mk:11: check-regress] Error 13
>>> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659987
>>> > --- the current script: ALL - master - based. - probably some
>>> breaking changes ..
>>> > ENV PROJ_GIT_HASH abf680353d1e7088c8751eea5a429ca1ffd22303
>>> > ENV GEOS_GIT_HASH 47f145efda619feb439cb5a69ab0886c4e872579
>>> > ENV GDAL_GIT_HASH 561ba5c11fedfde81008dfed58ac61f0250d936b
>>> > ENV POSTGIS_GIT_HASH 7a1eb0e60f84f8fd08c87623ee83d5e5e15562c2
>>> > this is the 12-master Dockerfile
>>> https://github.com/postgis/docker-postgis/blob/8268956668355447d8e3bde81bca5cb47e3ee54e/12-master/Dockerfile
>>> > in this case: I have to test with the last week HASH-es .. and try to
>>> find the latest working versions .. :-(
>>> > best,
>>> > Imre
>>> K, 13:06):
>>> >> > Where's the pipeline to push images there described ?
>>> >> As I know - the "update" part ( calling ./update.sh ) is still
>>> manual.
>>> https://github.com/postgis/docker-postgis/blob/master/.github/workflows/main.yml
>>> >> I have created a manal update -
>>> >> If it is urgent: now the current workflow - for a local update +
>>> build
>>> >> git clone https://github.com/postgis/docker-postgis.git
>>> >> cd docker-postgis
>>> >> ./update.sh
>>> >> Imre
>>> >> Sandro Santilli <strk at kbt.io> ezt írta (időpont: 2021. máj. 18., K,
>>> 12:21):
>>> >>> According to docker hub
>>> >>> the 12-master image was last pushed a day ago, but the
>>> >>> version of PostGIS there is 67 commits behind the current
>>> >>> master. Where's the pipeline to push images there described ?
>>> >>> --strk;
>>> >>> _______________________________________________
>>> >>> postgis-devel mailing list
>>> >>> postgis-devel at lists.osgeo.org
>>> >>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210605/83c9be30/attachment.html>
