[postgis-devel] Questions about POSTGIS_DEBUG
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jun 14 11:40:54 PDT 2021
I have more-or-less totally stopped using POSTGIS_DEBUG for anything... during development I usually have some temporary elog() statements, and for things I want to keep around post-development that aren't going to generate too much data I just downgrade them to elog(debug) level. For day-to-day debugging on tickets and so on, for already released code I usually head straight for the debugger, don't turn on POSTGIS_DEBUG. I find turning it on just results in a firehose of output from non-related modules from which it's too much work to extract the parts I actually care about.
P.
> On Jun 14, 2021, at 6:41 AM, Han Wang <hanwgeek at gmail.com> wrote:
> Hi Giuseppe,
> Please forgive me if I was unclear.
> I call `POSTGIS_DEBUG` in some functions to debug but when I run .sql test script in /regress folder, I did not see any output related to the debug information. Besides, I have already set the `POSTGIS_DEBUG_LEVEL` to 1.
> Best regards,
> Han
> On Mon, Jun 14, 2021 at 8:37 PM Giuseppe Broccolo <g.broccolo.7 at gmail.com> wrote:
> Hi Han,
> Il giorno lun 14 giu 2021 alle ore 12:30 Han Wang <hanwgeek at gmail.com> ha scritto:
> Hi all,
> Currently I am using `POSTGIS_DEBUG` in the /regress tests. But I haven't seen any debug output in console or regress logs. I would like to know where can I get these information?
> postgis_debug should be a method used to log debug messages during the execution of C modules. What do you mean with "I am using `POSTGIS_DEBUG` in the /regress tests."?
> Anyway, logging is configured at PostgreSQL level, did you eventually check also the PostgreSQL server's logs?
> Giuseppe.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
