[postgis-devel] ST_Reverse issues
Sandro Santilli
strk at kbt.io
Thu Jun 24 07:53:14 PDT 2021
I'm facing dragons with this query:
WITH inp AS (
SELECT 'LINESTRING(0 0,10 0,5 5,0 0)'::geometry g
UNION ALL
SELECT 'LINESTRING(-1.8 -6,-1.8 -7,-1.2 -7,-1.2 -6,-1.8
-6)'::geometry
SELECT
-- We expect both fields being true
ST_AsText(g) straight,
ST_AsText(ST_Reverse(g)) reverse,
ST_IsPolygonCW(ST_MakePolygon(ST_Normalize(g))) cw,
ST_IsPolygonCW(ST_MakePolygon(ST_Normalize(ST_Reverse(g)))) cw_when_reverted
FROM inp;
The result I'm getting:
-[ RECORD 1 ]----+----------------------------------------------------
straight | LINESTRING(0 0,10 0,5 5,0 0)
reverse | LINESTRING(0 0,5 5,10 0,0 0)
cw | t
cw_when_reverted | t
-[ RECORD 2 ]----+----------------------------------------------------
straight | LINESTRING(-1.8 -6,-1.8 -7,-1.2 -7,-1.2 -6,-1.8 -6)
reverse | LINESTRING(-1.8 -6,-1.2 -6,-1.2 -7,-1.8 -7,-1.8 -6)
cw | f
cw_when_reverted | f
Note how "cw" and "cw_when_reverted" have the same value.
If writing the query in a different way I get correct results:
WITH inp AS (
SELECT 't1' lbl, 'LINESTRING(0 0,10 0,5 5,0 0)'::geometry g
UNION ALL
SELECT 't2', 'LINESTRING(-1.8 -6,-1.8 -7,-1.2 -7,-1.2 -6,-1.8 -6)'::geometry
back_and_forw AS (
SELECT lbl, g, st_reverse(g) rg from inp
SELECT
lbl,
ST_AsText(g) forw,
ST_AsText(rg) back,
ST_IsPolygonCW(ST_MakePolygon(g)) forw_cw,
ST_IsPolygonCW(ST_MakePolygon(rg)) back_cw
FROM back_and_forw;
-[ RECORD 1 ]------------------------------------------------
lbl | t1
forw | LINESTRING(0 0,10 0,5 5,0 0)
back | LINESTRING(0 0,5 5,10 0,0 0)
forw_cw | f
back_cw | t
-[ RECORD 2 ]------------------------------------------------
lbl | t2
forw | LINESTRING(-1.8 -6,-1.8 -7,-1.2 -7,-1.2 -6,-1.8 -6)
back | LINESTRING(-1.8 -6,-1.2 -6,-1.2 -7,-1.8 -7,-1.8 -6)
forw_cw | f
back_cw | t
Can you imagine reasons for this ? The only thing that comes to my
mind is we're doing reverse in-place w/out first taking a copy of the
parameter, thus changing also the input passed to ST_Reverse().
This is happening with
POSTGIS="3.1.2dev 3.1.1-38-gb02ee9513" [EXTENSION] PGSQL="120" GEOS="3.8.2dev-CAPI-1.13.4"
--strk;
() Free GIS & Flash consultant/developer
/\ https://strk.kbt.io/services.html
