[postgis-devel] About the tests for GSoC
Han Wang
hanwgeek at gmail.com
Wed Mar 31 02:02:22 PDT 2021
Hi Ayoub,
I got the same problem with you.
And I check the `extension` folder, there is not a `.control` file indeed.
However, the `make install` command puts postgis extension at
`postgresql/share/contrib/postgis-3.2`.
Maybe you can read the manual to get more information,
http://postgis.net/stuff/postgis-3.2.pdf.
Best regards,
Han
Justin Pryzby <pryzby at telsasoft.com> 于2021年3月30日周二 下午10:51写道:
> On Tue, Mar 30, 2021 at 03:47:41PM +0100, FATIHI Ayoub wrote:
> > I have tried to install postgresql dev version, and I have done it:
> > [image: image.png]
> > And I have also compiled postgis from source(after installing :GEOS,
> Proj,
> > GDAL, LibXML2 and JSON-C.):
> > [image: image.png]
> > But when I want to CREATE EXTENSION postgis; ; but I get this error:
> > [image: image.png]
> You said that you compiled postgis, but did you install it to the same
> location
> as postgres ?
> Also, it's much better if you include the text of the error message rather
> than an
> picture showing the error.
> Justin Pryzby
> System Administrator
> Telsasoft
> +1-952-707-8581
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210331/ea28e3a5/attachment.html>
