[postgis-devel] postgis-devel Digest, Vol 215, Issue 11
FATIHI Ayoub
ayoubfatihi1999 at gmail.com
Wed Mar 31 12:29:19 PDT 2021
Hi Han,
Thank you for your help, I already got over that problem by using the : sudo
./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config.
You have just to indicate where the pgconfig file is located.
Best regards.
On Wed, Mar 31, 2021 at 8:02 PM <postgis-devel-request at lists.osgeo.org>
wrote:
> Send postgis-devel mailing list submissions to
> postgis-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-devel digest..."
> Today's Topics:
> 1. Re: About the tests for GSoC (Han Wang)
> Message: 1
> Date: Wed, 31 Mar 2021 17:02:22 +0800
> From: Han Wang <hanwgeek at gmail.com>
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Subject: Re: [postgis-devel] About the tests for GSoC
> Message-ID:
> <CADCmNp316HKB9JXmXeSFM5=
> uT2PnATJvA1awOYKLs8V+L3D3KQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Ayoub,
> I got the same problem with you.
> And I check the `extension` folder, there is not a `.control` file indeed.
> However, the `make install` command puts postgis extension at
> `postgresql/share/contrib/postgis-3.2`.
> Maybe you can read the manual to get more information,
> http://postgis.net/stuff/postgis-3.2.pdf.
> Best regards,
> Han
> Justin Pryzby <pryzby at telsasoft.com> ?2021?3?30??? ??10:51???
> > On Tue, Mar 30, 2021 at 03:47:41PM +0100, FATIHI Ayoub wrote:
> > > I have tried to install postgresql dev version, and I have done it:
> > > [image: image.png]
> > > And I have also compiled postgis from source(after installing :GEOS,
> > Proj,
> > > GDAL, LibXML2 and JSON-C.):
> > > [image: image.png]
> > > But when I want to CREATE EXTENSION postgis; ; but I get this error:
> > > [image: image.png]
> > You said that you compiled postgis, but did you install it to the same
> > location
> > as postgres ?
> > Also, it's much better if you include the text of the error message
> rather
> > than an
> > picture showing the error.
> > Justin Pryzby
> > System Administrator
> > Telsasoft
> > +1-952-707-8581
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210331/ea28e3a5/attachment-0001.html
> Subject: Digest Footer
> End of postgis-devel Digest, Vol 215, Issue 11
FATIHI Ayoub
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210331/325510f1/attachment.html>
