[postgis-devel] Error making postgis
Regina Obe
lr at pcorp.us
Sun May 2 00:49:06 PDT 2021
Ayoub,
Issue should be fixed now. Can you give it another try.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Ayoub FATIHI
Sent: Friday, April 30, 2021 9:47 PM
To: postgis devel <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Error making postgis
Actually ther was this warnings:
lwgeom_geos.c:147:2: warning: implicit declaration of function ‘GEOSCoordSeq_copyToBuffer’; did you mean ‘GEOSCoordSeq_clone’? [-Wimplicit-function-declaration]
147 | GEOSCoordSeq_copyToBuffer(cs, (double*) pa->serialized_pointlist, (dims == 3), 0);
| GEOSCoordSeq_clone
lwgeom_geos.c: In function ‘ptarray_to_GEOSCoordSeq’:
lwgeom_geos.c:280:8: warning: implicit declaration of function ‘GEOSCoordSeq_copyFromBuffer’ [-Wimplicit-function-declaration]
280 | sq = GEOSCoordSeq_copyFromBuffer((const double*) pa->serialized_pointlist, pa->npoints, FLAGS_GET_Z(pa->flags), FLAGS_GET_M(pa->flags));
lwgeom_geos.c:280:6: warning: assignment to ‘GEOSCoordSeq’ {aka ‘struct GEOSCoordSeq_t *’} from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
And this warning was repeated a bunch of time :
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -fPIC "-I../../liblwgeom" -I/usr/include -I/usr/include/libxml2 -I/usr/include/json-c -DNDEBUG -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -I/usr/include/gdal "-I../../libpgcommon" -I../rt_core -I. -I./ -I/usr/local/pgsql/include/server -I/usr/local/pgsql/include/internal -D_GNU_SOURCE -c -o rtpg_internal.o rtpg_internal.c
In file included from /usr/include/gdal/cpl_port.h:66,
from /usr/include/gdal/gdal.h:45,
from ../rt_core/librtcore.h:126,
from rtpostgis.h:39,
from rtpg_internal.h:33,
from rtpg_internal.c:34:
/usr/include/gdal/cpl_config.h:296: warning: "PACKAGE_URL" redefined
296 | #define PACKAGE_URL ""
In file included from /usr/local/pgsql/include/server/c.h:54,
from /usr/local/pgsql/include/server/postgres.h:46,
from rtpg_internal.c:31:
/usr/local/pgsql/include/server/pg_config.h:806: note: this is the location of the previous definition
806 | #define PACKAGE_URL "https://www.postgresql.org/"
Here is the full output : https://github.com/ayoubft/postgis_error_file/blob/main/make_result.txt
FATIHI Ayoub
On Sat, May 1, 2021 at 12:40 AM Ayoub FATIHI <ayoubfatihi1999 at gmail.com <mailto:ayoubfatihi1999 at gmail.com> > wrote:
Hi community,
I was re-installing PostGIS with PostgreSQL from source.
And I have this problem :
Postgres compile just fine. But ...
When I run make for postgis, I get this error:
collect2: error: ld returned 1 exit status
make[2]: *** [Makefile:84: raster2pgsql] Error 1
make[2]: Leaving directory '/usr/local/src/postgis/raster/loader'
make[1]: *** [Makefile:35: rtloader] Error 2
make[1]: Leaving directory '/usr/local/src/postgis/raster'
make: *** [GNUmakefile:22: all] Error 1
Noting also that config when done says:
PostGIS is now configured for x86_64-pc-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros
C++ compiler (Wagyu): gcc -std=c++11 -x c++
CPPFLAGS: -I/usr/include -I/usr/include/libxml2 -I/usr/include/json-c -DNDEBUG
LDFLAGS: -lm
SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-------------- Additional Info -------------
Interrupt Tests: DISABLED use: --with-interrupt-tests to enable
-------------- Dependencies --------------
GEOS config: /usr/bin/geos-config
GEOS version: 3.8.0
GDAL config: /usr/bin/gdal-config
GDAL version: 3.0.4
PostgreSQL config: /usr/local/pgsql/bin/pg_config
PostgreSQL version: PostgreSQL 14devel
PROJ4 version: 63
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.10
JSON-C support: yes
protobuf support: yes
protobuf-c version: 1003003
PCRE support: yes
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
Address Standardizer support: enabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets:
dblatex:
convert:
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
configure: WARNING: --------- GEOS VERSION WARNING ------------
configure WARNING: You are building against GEOS 3.8.0.
configure: WARNING:
configure: WARNING: To take advantage of _all_ the features of
configure: WARNING: PostGIS, GEOS 3.9.0 or higher is required.
configure: WARNING:
configure: WARNING: For _many_ features, GEOS 3.6.0 is enough.
configure: WARNING:
configure: WARNING: We recommend GEOS 3.8.0 or higher
configure: WARNING:
configure: WARNING: You can download the latest versions from
configure: WARNING: http://geos.osgeo.org/
configure: WARNING:
Any ideas how to solve this problem ?
FATIHI Ayoub
FATIHI Ayoub
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210502/9dd6b7a7/attachment-0001.html>
