[postgis-devel] postgis-devel Digest, Vol 217, Issue 1
Ayoub FATIHI
ayoubfatihi1999 at gmail.com
Sun May 2 06:18:21 PDT 2021
Yes, now is working.
Thank you.
On Sun, May 2, 2021 at 7:49 AM <postgis-devel-request at lists.osgeo.org>
wrote:
> Send postgis-devel mailing list submissions to
> postgis-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-devel digest..."
> Today's Topics:
> 1. Re: Error making postgis (Regina Obe)
> 2. Re: Error making postgis (Regina Obe)
> Message: 1
> Date: Sun, 2 May 2021 03:20:44 -0400
> From: "Regina Obe" <lr at pcorp.us>
> To: "'PostGIS Development Discussion'" <postgis-devel at lists.osgeo.org>
> Subject: Re: [postgis-devel] Error making postgis
> Message-ID: <000c01d73f23$aae0bf60$00a23e20$@pcorp.us>
> Content-Type: text/plain; charset="utf-8"
> Ayoub,
> I don?t think it?s anything wrong you are doing. Looks like all Bots are
> failing at this point with GEOS related errors.
> Thanks for noticing,
> Regina
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
> Behalf Of Ayoub FATIHI
> Sent: Friday, April 30, 2021 9:47 PM
> To: postgis devel <postgis-devel at lists.osgeo.org>
> Actually ther was this warnings:
> lwgeom_geos.c:147:2: warning: implicit declaration of function
> ?GEOSCoordSeq_copyToBuffer?; did you mean ?GEOSCoordSeq_clone??
> [-Wimplicit-function-declaration]
> 147 | GEOSCoordSeq_copyToBuffer(cs, (double*) pa->serialized_pointlist,
> (dims == 3), 0);
> | GEOSCoordSeq_clone
> lwgeom_geos.c: In function ?ptarray_to_GEOSCoordSeq?:
> lwgeom_geos.c:280:8: warning: implicit declaration of function
> ?GEOSCoordSeq_copyFromBuffer? [-Wimplicit-function-declaration]
> 280 | sq = GEOSCoordSeq_copyFromBuffer((const double*)
> pa->serialized_pointlist, pa->npoints, FLAGS_GET_Z(pa->flags),
> FLAGS_GET_M(pa->flags));
> lwgeom_geos.c:280:6: warning: assignment to ?GEOSCoordSeq? {aka ?struct
> GEOSCoordSeq_t *?} from ?int? makes pointer from integer without a cast
> [-Wint-conversion]
> And this warning was repeated a bunch of time :
> gcc -Wall -Wmissing-prototypes -Wpointer-arith
> -Wdeclaration-after-statement -Werror=vla -Wendif-labels
> -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type
> -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard
> -Wno-format-truncation -Wno-stringop-truncation -O2 -fPIC
> "-I../../liblwgeom" -I/usr/include -I/usr/include/libxml2
> -I/usr/include/json-c -DNDEBUG -std=gnu99 -g -O2 -fno-math-errno
> -fno-signed-zeros -I/usr/include/gdal "-I../../libpgcommon" -I../rt_core
> -I. -I./ -I/usr/local/pgsql/include/server
> -I/usr/local/pgsql/include/internal -D_GNU_SOURCE -c -o rtpg_internal.o
> rtpg_internal.c
> In file included from /usr/include/gdal/cpl_port.h:66,
> from /usr/include/gdal/gdal.h:45,
> from ../rt_core/librtcore.h:126,
> from rtpostgis.h:39,
> from rtpg_internal.h:33,
> from rtpg_internal.c:34:
> /usr/include/gdal/cpl_config.h:296: warning: "PACKAGE_URL" redefined
> 296 | #define PACKAGE_URL ""
> In file included from /usr/local/pgsql/include/server/c.h:54,
> from /usr/local/pgsql/include/server/postgres.h:46,
> from rtpg_internal.c:31:
> /usr/local/pgsql/include/server/pg_config.h:806: note: this is the
> location of the previous definition
> 806 | #define PACKAGE_URL "https://www.postgresql.org/"
> Here is the full output :
> https://github.com/ayoubft/postgis_error_file/blob/main/make_result.txt
> FATIHI Ayoub
> On Sat, May 1, 2021 at 12:40 AM Ayoub FATIHI <ayoubfatihi1999 at gmail.com
> <mailto:ayoubfatihi1999 at gmail.com> > wrote:
> Hi community,
> I was re-installing PostGIS with PostgreSQL from source.
> And I have this problem :
> Postgres compile just fine. But ...
> When I run make for postgis, I get this error:
> collect2: error: ld returned 1 exit status
> make[2]: *** [Makefile:84: raster2pgsql] Error 1
> make[2]: Leaving directory '/usr/local/src/postgis/raster/loader'
> make[1]: *** [Makefile:35: rtloader] Error 2
> make[1]: Leaving directory '/usr/local/src/postgis/raster'
> make: *** [GNUmakefile:22: all] Error 1
> Noting also that config when done says:
> PostGIS is now configured for x86_64-pc-linux-gnu
> -------------- Compiler Info -------------
> C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno
> -fno-signed-zeros
> C++ compiler (Wagyu): gcc -std=c++11 -x c++
> CPPFLAGS: -I/usr/include -I/usr/include/libxml2
> LDFLAGS: -lm
> SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
> -------------- Additional Info -------------
> Interrupt Tests: DISABLED use: --with-interrupt-tests to enable
> -------------- Dependencies --------------
> GEOS config: /usr/bin/geos-config
> GEOS version: 3.8.0
> GDAL config: /usr/bin/gdal-config
> GDAL version: 3.0.4
> PostgreSQL config: /usr/local/pgsql/bin/pg_config
> PostgreSQL version: PostgreSQL 14devel
> PROJ4 version: 63
> Libxml2 config: /usr/bin/xml2-config
> Libxml2 version: 2.9.10
> JSON-C support: yes
> protobuf support: yes
> protobuf-c version: 1003003
> PCRE support: yes
> Perl: /usr/bin/perl
> --------------- Extensions ---------------
> PostGIS Raster: enabled
> PostGIS Topology: enabled
> SFCGAL support: disabled
> Address Standardizer support: enabled
> -------- Documentation Generation --------
> xsltproc: /usr/bin/xsltproc
> xsl style sheets:
> dblatex:
> convert:
> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> configure: WARNING: --------- GEOS VERSION WARNING ------------
> configure WARNING: You are building against GEOS 3.8.0.
> configure: WARNING:
> configure: WARNING: To take advantage of _all_ the features of
> configure: WARNING: PostGIS, GEOS 3.9.0 or higher is required.
> configure: WARNING:
> configure: WARNING: For _many_ features, GEOS 3.6.0 is enough.
> configure: WARNING:
> configure: WARNING: We recommend GEOS 3.8.0 or higher
> configure: WARNING:
> configure: WARNING: You can download the latest versions from
> configure: WARNING: http://geos.osgeo.org/
> configure: WARNING:
> Any ideas how to solve this problem ?
> FATIHI Ayoub
> FATIHI Ayoub
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210502/677d9d36/attachment-0001.html
> Message: 2
> Date: Sun, 2 May 2021 03:49:06 -0400
> Message-ID: <001301d73f27$a1af3e90$e50dbbb0$@pcorp.us>
> Ayoub,
> Issue should be fixed now. Can you give it another try.
> Thanks,
> Regina
> (dims == 3), 0);
> | GEOSCoordSeq_clone
> [-Wint-conversion]
> rtpg_internal.c
> FATIHI Ayoub
> Hi community,
> -fno-signed-zeros
> LDFLAGS: -lm
> GEOS version: 3.8.0
> GDAL version: 3.0.4
> PROJ4 version: 63
> JSON-C support: yes
> PCRE support: yes
> Perl: /usr/bin/perl
> xsl style sheets:
> dblatex:
> convert:
> configure: WARNING:
> configure: WARNING:
> configure: WARNING:
> configure: WARNING:
> configure: WARNING:
> FATIHI Ayoub
> FATIHI Ayoub
> URL: <
> http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210502/9dd6b7a7/attachment.html
> Subject: Digest Footer
> End of postgis-devel Digest, Vol 217, Issue 1
FATIHI Ayoub
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210502/9bd5e6ca/attachment-0001.html>
