[postgis-devel] Much slower processing on GEOS 3.9.0 versus 3.8.0 for geodesic area calculation - Upgrade to PROJ 7.2.1 causes issue
Raúl Marín raul at rmr.ninja
Fri May 14 18:38:13 PDT 2021
On 15/5/21 1:58, Paul Ramsey wrote:
 > The fix is a little invasive, I'm "so so" on backporting it into the
stable branches. Interested in comments regarding that.
Adding fcinfo everywhere was a pain, so it's only fair that removing it
would be too. I'm not against backporting it, but I'm not sure the gain
justifies the risk and effort.
I like those tricks to get Postgis schema without the fcinfo. If I
recall correctly somebody (mobilitydb?) had some issues related to it
because they were calling Postgis from C without passing the fcinfo.
This change should avoid that, I think.
 > It works cleanly for me locally and evades the start-up cost of proj.
I haven't done anything to make the cache access any faster yet, but
it's a low priority since most people only have a handful of projections
in their cache anyways.
The cache can hold up to 128 transformations, which should be enough for
most cases, and has some basic intelligence to remove the least used
objects when it's full but it might need to be improved if being full
ends up being the norm. It's really simple so I don't expect any
performance issue coming from that unless the cache size is increased.
Regards,
Raúl.
