[postgis-devel] docker hub image is behind
Imre Samu pella.samu at gmail.com
Tue May 18 04:06:08 PDT 2021
>  Where's the pipeline to push images there described ?
As I know - the "update" part ( calling ./update.sh )  is still manual.
https://github.com/postgis/docker-postgis/blob/master/.github/workflows/main.yml
I have created a manal update -
https://github.com/postgis/docker-postgis/pull/235
If it is urgent:  now the current workflow - for a local update + build
git clone https://github.com/postgis/docker-postgis.git
cd docker-postgis
./update.sh
docker build -t postgis:13-master ./13-master
Imre
Sandro Santilli <strk at kbt.io> ezt írta (időpont: 2021. máj. 18., K, 12:21):
> According to docker hub
> the 12-master image was last pushed a day ago, but the
> version of PostGIS there is 67 commits behind the current
> master. Where's the pipeline to push images there described ?
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210518/6cfd6976/attachment-0001.html>
