[postgis-devel] docker hub image is behind
Imre Samu
pella.samu at gmail.com
Tue May 18 08:17:27 PDT 2021
Ouch; Failed.
12-master:
Run tests: 150
Failed: 17
make: *** [runtest.mk:11: check-regress] Error 17
full log:
https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659927
13-master:
Run tests: 150
Failed: 13
make: *** [runtest.mk:11: check-regress] Error 13
https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659987
--- the current script: ALL - master - based. - probably some breaking
changes ..
ENV SFCGAL_GIT_HASH 0beb9d6dde86467d412e70037dca0e00091e673e
ENV PROJ_GIT_HASH abf680353d1e7088c8751eea5a429ca1ffd22303
ENV GEOS_GIT_HASH 47f145efda619feb439cb5a69ab0886c4e872579
ENV GDAL_GIT_HASH 561ba5c11fedfde81008dfed58ac61f0250d936b
ENV POSTGIS_GIT_HASH 7a1eb0e60f84f8fd08c87623ee83d5e5e15562c2
this is the 12-master Dockerfile
https://github.com/postgis/docker-postgis/blob/8268956668355447d8e3bde81bca5cb47e3ee54e/12-master/Dockerfile
in this case: I have to test with the last week HASH-es .. and try to find
the latest working versions .. :-(
best,
Imre
Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2021. máj. 18., K,
13:06):
> > Where's the pipeline to push images there described ?
> As I know - the "update" part ( calling ./update.sh ) is still manual.
> https://github.com/postgis/docker-postgis/blob/master/.github/workflows/main.yml
> I have created a manal update -
> If it is urgent: now the current workflow - for a local update + build
> git clone https://github.com/postgis/docker-postgis.git
> cd docker-postgis
> ./update.sh
> docker build -t postgis:13-master ./13-master
> Imre
> Sandro Santilli <strk at kbt.io> ezt írta (időpont: 2021. máj. 18., K,
> 12:21):
>> According to docker hub
>> the 12-master image was last pushed a day ago, but the
>> version of PostGIS there is 67 commits behind the current
>> master. Where's the pipeline to push images there described ?
>> --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210518/9ef57fc1/attachment.html>
