[postgis-devel] docker hub image is behind
Giuseppe Broccolo
g.broccolo.7 at gmail.com
Tue May 18 08:37:42 PDT 2021
Hi Imre,
Today GitHub has reported some issues about CI actions on their side (
https://www.githubstatus.com/). Don't know if this can impact the workflow.
Giuseppe.
Il giorno mar 18 mag 2021 alle ore 16:17 Imre Samu <pella.samu at gmail.com>
ha scritto:
> Ouch; Failed.
> 12-master:
> Run tests: 150
> Failed: 17
> make: *** [runtest.mk:11: check-regress] Error 17
> full log:
> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659927
> 13-master:
> Run tests: 150
> Failed: 13
> make: *** [runtest.mk:11: check-regress] Error 13
> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659987
> --- the current script: ALL - master - based. - probably some breaking
> changes ..
> ENV SFCGAL_GIT_HASH 0beb9d6dde86467d412e70037dca0e00091e673e
> ENV PROJ_GIT_HASH abf680353d1e7088c8751eea5a429ca1ffd22303
> ENV GEOS_GIT_HASH 47f145efda619feb439cb5a69ab0886c4e872579
> ENV GDAL_GIT_HASH 561ba5c11fedfde81008dfed58ac61f0250d936b
> ENV POSTGIS_GIT_HASH 7a1eb0e60f84f8fd08c87623ee83d5e5e15562c2
> this is the 12-master Dockerfile
> https://github.com/postgis/docker-postgis/blob/8268956668355447d8e3bde81bca5cb47e3ee54e/12-master/Dockerfile
> in this case: I have to test with the last week HASH-es .. and try to find
> the latest working versions .. :-(
> best,
> Imre
> Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2021. máj. 18., K,
> 13:06):
>> > Where's the pipeline to push images there described ?
>> As I know - the "update" part ( calling ./update.sh ) is still manual.
>> https://github.com/postgis/docker-postgis/blob/master/.github/workflows/main.yml
>> I have created a manal update -
>> If it is urgent: now the current workflow - for a local update + build
>> git clone https://github.com/postgis/docker-postgis.git
>> cd docker-postgis
>> ./update.sh
>> docker build -t postgis:13-master ./13-master
>> Imre
>> Sandro Santilli <strk at kbt.io> ezt írta (időpont: 2021. máj. 18., K,
>> 12:21):
>>> According to docker hub
>>> the 12-master image was last pushed a day ago, but the
>>> version of PostGIS there is 67 commits behind the current
>>> master. Where's the pipeline to push images there described ?
>>> --strk;
>>> postgis-devel mailing list
>>> postgis-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210518/4988747b/attachment.html>
