[postgis-devel] docker hub image is behind
Imre Samu
pella.samu at gmail.com
Tue May 18 09:43:36 PDT 2021
Thank you, Giuseppe and Phillip - for the tips!
I have tried - to build on my local machine, and has a similar result :-(
docker build -t postgis:13-master ./13-master
Run tests: 150
Failed: 23
make: *** [runtest.mk:11: check-regress] Error 23
I have refreshed to the latest proj,gdal .. And waiting for the new github
test.
https://github.com/postgis/docker-postgis/pull/235
For Geos 3.10 - just only this issue reported:
"ClipByBox2D against GEOS 3.10 head failing"
https://trac.osgeo.org/postgis/ticket/4904
> Before putting much work into bisecting commit logs and trying to find
> the most recent working commit,
probably, I just lock the ~ one-month-old PROJ + GEOS master version
Or just manually updating the PostGIS hash
( without finding the real root cause )
Imre
Phillip Ross <phillip.w.g.ross+postgis at gmail.com> ezt írta (időpont: 2021.
máj. 18., K, 17:49):
> Hi Imre,
> I took a look at the logs and the failures look a little peculiar. It
> might be a github actions issue, as Giuseppe mentioned.
> the most recent working commit, you might want to try to just re-run
> the jobs in the actions tab and see if the failures were an
> intermittent issue.
> Thanks!
> - Phillip
> On Tue, May 18, 2021 at 11:17 AM Imre Samu <pella.samu at gmail.com> wrote:
> > Ouch; Failed.
> > 12-master:
> > Run tests: 150
> > Failed: 17
> > make: *** [runtest.mk:11: check-regress] Error 17
> > full log:
> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659927
> > 13-master:
> > Run tests: 150
> > Failed: 13
> > make: *** [runtest.mk:11: check-regress] Error 13
> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659987
> > --- the current script: ALL - master - based. - probably some
> breaking changes ..
> > ENV SFCGAL_GIT_HASH 0beb9d6dde86467d412e70037dca0e00091e673e
> > ENV PROJ_GIT_HASH abf680353d1e7088c8751eea5a429ca1ffd22303
> > ENV GEOS_GIT_HASH 47f145efda619feb439cb5a69ab0886c4e872579
> > ENV GDAL_GIT_HASH 561ba5c11fedfde81008dfed58ac61f0250d936b
> > ENV POSTGIS_GIT_HASH 7a1eb0e60f84f8fd08c87623ee83d5e5e15562c2
> > this is the 12-master Dockerfile
> https://github.com/postgis/docker-postgis/blob/8268956668355447d8e3bde81bca5cb47e3ee54e/12-master/Dockerfile
> > in this case: I have to test with the last week HASH-es .. and try to
> find the latest working versions .. :-(
> > best,
> > Imre
> > Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2021. máj. 18., K,
> 13:06):
> >> > Where's the pipeline to push images there described ?
> >> As I know - the "update" part ( calling ./update.sh ) is still manual.
> https://github.com/postgis/docker-postgis/blob/master/.github/workflows/main.yml
> >> I have created a manal update -
> >> If it is urgent: now the current workflow - for a local update + build
> >> git clone https://github.com/postgis/docker-postgis.git
> >> cd docker-postgis
> >> ./update.sh
> >> Imre
> >> Sandro Santilli <strk at kbt.io> ezt írta (időpont: 2021. máj. 18., K,
> 12:21):
> >>> According to docker hub
> >>> the 12-master image was last pushed a day ago, but the
> >>> version of PostGIS there is 67 commits behind the current
> >>> master. Where's the pipeline to push images there described ?
> >>> --strk;
> >>> _______________________________________________
> >>> postgis-devel mailing list
> >>> postgis-devel at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210518/ba0d396f/attachment-0001.html>
