[postgis-devel] docker hub image is behind
Imre Samu pella.samu at gmail.com
Wed May 19 09:15:35 PDT 2021
my guess:  probably it is a Geos 3.10 related problem.
And as I see: the similar - "latest" CI check has been removed on Apr 28,
2021 by Paul Ramsey
https://github.com/postgis/postgis/commit/982d725906c4ae69dab3d11e69432f8a7e51b90e
the latest "~good???" Postgis version with the new geos:
2851cd1908dc138d6a6ec389fdbedc8fc93f5e73   ( ~ Apr 27, 2021 )
IMHO: options:
a.) wait for the "root cause" fix
b.) set Postgis to  ~Apr 27, 2021 ->
https://github.com/postgis/docker-postgis/pull/236/files
  ( from d5f7a2adc923869ebe17b5fd0a6fa299d5b9c20c   ~ Commits on Mar 30,
2021 )
c.) other alternatives
Imre
Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2021. máj. 18., K,
18:43):
> Thank you, Giuseppe and  Phillip -  for the tips!
> I have tried - to build on my local machine, and has a similar result  :-(
> docker build -t postgis:13-master ./13-master
> Run tests: 150
> Failed: 23
> make: *** [runtest.mk:11: check-regress] Error 23
> I have refreshed to the latest proj,gdal .. And waiting for the new github
> test.
>     https://github.com/postgis/docker-postgis/pull/235
> For Geos 3.10 -  just only this issue reported:
> "ClipByBox2D against GEOS 3.10 head failing"
> https://trac.osgeo.org/postgis/ticket/4904
> > Before putting much work into bisecting commit logs and trying to find
> > the most recent working commit,
> probably, I just lock the  ~ one-month-old PROJ + GEOS  master version
> Or just manually updating the PostGIS hash
> ( without finding the real root cause )
> Imre
> Phillip Ross <phillip.w.g.ross+postgis at gmail.com> ezt írta (időpont:
> 2021. máj. 18., K, 17:49):
>> Hi Imre,
>> I took a look at the logs and the failures look a little peculiar.  It
>> might be a github actions issue, as Giuseppe mentioned.
>> the most recent working commit, you might want to try to just re-run
>> the jobs in the actions tab and see if the failures were an
>> intermittent issue.
>> Thanks!
>> - Phillip
>> On Tue, May 18, 2021 at 11:17 AM Imre Samu <pella.samu at gmail.com> wrote:
>> > Ouch;  Failed.
>> > 12-master:
>> > Run tests: 150
>> > Failed: 17
>> > make: *** [runtest.mk:11: check-regress] Error 17
>> > full log:
>> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659927
>> > 13-master:
>> > Run tests: 150
>> > Failed: 13
>> > make: *** [runtest.mk:11: check-regress] Error 13
>> https://github.com/postgis/docker-postgis/pull/235/checks?check_run_id=2609659987
>> > ---  the current script:    ALL - master - based. - probably some
>> breaking changes ..
>> > ENV SFCGAL_GIT_HASH 0beb9d6dde86467d412e70037dca0e00091e673e
>> > ENV PROJ_GIT_HASH abf680353d1e7088c8751eea5a429ca1ffd22303
>> > ENV GEOS_GIT_HASH 47f145efda619feb439cb5a69ab0886c4e872579
>> > ENV GDAL_GIT_HASH 561ba5c11fedfde81008dfed58ac61f0250d936b
>> > ENV POSTGIS_GIT_HASH 7a1eb0e60f84f8fd08c87623ee83d5e5e15562c2
>> > this is the 12-master Dockerfile
>> https://github.com/postgis/docker-postgis/blob/8268956668355447d8e3bde81bca5cb47e3ee54e/12-master/Dockerfile
>> > in this case: I have to test with the last week HASH-es .. and try to
>> find the latest working versions ..   :-(
>> > best,
>> >  Imre
>> 13:06):
>> >> >  Where's the pipeline to push images there described ?
>> >> As I know - the "update" part ( calling ./update.sh )  is still manual.
>> https://github.com/postgis/docker-postgis/blob/master/.github/workflows/main.yml
>> >> I have created a manal update -
>> >> If it is urgent:  now the current workflow - for a local update + build
>> >> git clone https://github.com/postgis/docker-postgis.git
>> >> cd docker-postgis
>> >> ./update.sh
>> >> Imre
>> >> Sandro Santilli <strk at kbt.io> ezt írta (időpont: 2021. máj. 18., K,
>> 12:21):
>> >>> According to docker hub
>> >>> the 12-master image was last pushed a day ago, but the
>> >>> version of PostGIS there is 67 commits behind the current
>> >>> master. Where's the pipeline to push images there described ?
>> >>> --strk;
>> >>> _______________________________________________
>> >>> postgis-devel mailing list
>> >>> postgis-devel at lists.osgeo.org
>> >>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210519/d67f4f6e/attachment-0001.html>
